need help m8 lipo ?
can the m8 run on lipo what would i get a 3s 1000mah or somethin
Im using a 3s 2200mah 8c lipo myself without any problem. so yeah, you should be good with that 1.
On a side note: try going higher on the mAh. I find that the m8 with spektrum module drains the battery like hell. I have to charge them after 2 weekends of track time, by that, means I only run my buggy during the weekends.
good to know and u had to take the whole remote apart to do the lipo correct since its not a open battery tray like most
yup, have to tear it apart and do some soldering work on it.
wonder if there is a way to put it in the battery tray and hook it up in that and just slide it in and out does that make sense
heheh yeah it made sense, but i never thought of it really ahahah
well i am going to c if that would work would be easy acsess in and out now just some thinking and a dremel
| All times are GMT -7. It is currently 08:11 AM. |
