Multiple battery charger
I am looking for a charger that can charge multiple lipos at a time. A friend is getting her boys trucks(3) for xmas and is trying to figure out what charger to get.
Any recommendations? |
Charger recommendation really depends on what kind of batteries you're going to be charging.
Not knowing anything about what you plan on charging, consider a dual charger or a quad type charger that'll charge either 2 or 4 batteries at once. |
Just your basic lipo for bashing. 2s lipos, mid range mah, 20-30c.
There are no reasonably priced AC/DC powered multiple battery chargers. The Graupner I'm aware of is about $500. The Hyperion Duo3 is a true dual charger with 2 separate ports allowing it to charge 2 batts at once. The iMax Quattro is a 4 port type charger and will charge 4 batteries at once. There is quite a contrast in charger output power and cost between the two.
Hyperion - http://www.allerc.com/hyperion-eos06...er-p-4632.html iMax Quattro type charger as sold by HobbyKing - http://www.hobbycity.com/hobbycity/s...dProduct=10327 You'll need a separate power supply with either of these. Since you're only charging 2S lipos, there is one other - it has some limitations, designed for 3000mah or smaller 2S only - http://www.hobbycity.com/hobbycity/s...dProduct=10707 |
Thanks for the help.
| All times are GMT -7. It is currently 12:57 PM. |
