Steering servo
Is there any way to adjust steering servo limit?My steering does not seem to go far enuff.Please Help
Check your transmitter for EPA/endpoint/travel adjustments (different terms for the same thing). And dual rate, make sure it's turned up. What transmitter do you have?
If nothing left there, or you don't have those features, consider a longer servo horn. Or a shorter lever position on the other end of the link to the servo. What RC do you have? Be sure to not overdo it, you don't want to bind up the servo against the steering mechanism. |
Steering servo
This is on an losi eight my steering servo is HItec HS-645MG my radio is an Spektrum DX2
I know my DX3.0 came with the steering dual rate set at 70% for some odd reason, others have mentioned it too. I'd suggest checking that first, turn it up to 100%. Grip (thumb) button B, the middle one if I remember correctly, assuming that didn't change between the originals and the .0 versions.
Then set endpoints, both left and right. They should be able to go above 100% if needed. |
steering servo
Man you rock. With your info I went to the DX2 manual on-line and fixed it.Thank You!!!!!!!!:)
Good to hear, always glad to help out when I can. Thanks for the kind words.
| All times are GMT -7. It is currently 07:37 AM. |
