caste 5700 cogging issues
I am running a castle 5700 and sidewinder esc and I am having cogging issues. I am getting back into the hobby after about 15 years and this brushless game is very confusing....Can anyone of you gents help me out with this issue
Ran that same combo in my 2WD Slash and never had any cogging. What batteries are you using?
I am using turnigy 2s 5000mah lipos
I assume you're running with them fully charged? Do you have a castle link so you can check the programming in the esc? Is this a new setup? You have calibrated the radio to the esc, right?
I ran mine on Intellect 5000mah 2S 35C lipos. |
The most common causes I have seen for cogging.
(not in any particular order) 1. Firmware- some of the older versions were not very smooth on startup, update to the latest version for best performance. 2. Connections- check all of the connectors very closely, including battery, motor, and all receiver connections. 3. Overgeared- this can cause cogging and overheating, which will permanently damage the motor. 4. Overweight- Castle's Sidewinder and CMS-36 motors are designed for lightweight 1/10th scale machines. Heavyweight SC style trucks are too much for these smaller motors and ESC's. Unless of course you have the Sidewinder SC system with the Neu-Castle motor. I also see many motors that have been overheated and never have good startup quality again. If the cogging is minor it can often be "tuned out" with start power, throttle curve, timing and punch control. There really is no mystery around brushless motors; heat is your only real enemy with the Castle motors. If you get it good and dirty you may have to open it every year or so to clean/replace bearings. But if it stays pretty clean, and you dont overheat it, it should last for many years without any maintenance whatsoever. I recently sold a Mamba Max system (original) that I bought the day they were released from Castle. To the day I sold it, it ran just like it did when I opened the box, with no maintenance at all. Get yourself a temp gun if you dont already have one. Keep it under 175F and it should last and last. |
check all connections
I have a 5700 combo and it had serious cogging issues. Turned out that it had firmware that was very early. Once I flashed the ESC firmware and programmed it with the latest software it ran great. You could have just bought one that was sitting on a shelf for a while like I did. Batteries make a huge difference though, you will still get cogging if your batteries aren't up to the task. I have the 5700 in a SC10 and it absolutely rips with 5000 mAh 30C packs.
| All times are GMT -7. It is currently 06:49 PM. |
