Like Tree4Likes
Viper RC -
Old 04-20-2013, 08:24 PM
  #7666
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Bob Barry
I power it up, press the button again for about a second and then the solid green light switches to solid orange. That lets you know you are in 'link mode' and you can proceed on the Proguage.
If you are still having troubles, try re-setting up the ESC. Set end points at 100 and rebind
thanks, I was pushing the button for too long.
MikeXray is offline
Old 04-20-2013, 10:30 PM
  #7667
King DORK's Avatar
Trader Rating: 54 (100%+)
Needed a new esc to replace my old ass GTB which was starting to do "weird" things. After checking out many high end escs from several manufacturers I decided on the VTX10R BE. One of my teammates ordered one too, along with an 8.5 Viper motor. Hope these escs turn out to be all that since I sold myself and my friend pretty hard on them.
King DORK is offline
Old 04-21-2013, 04:59 AM
  #7668
Graveyard's Avatar
Originally Posted by weyant
out at our local track sunday and my boy was running his buggy and he cased one of the jumps and it shut of for a few seconds and the started back up again...never had that happen like that before thought it was a battery conection but its not that anyon have this happen to them before??
Yup...happened to me also. One month out of warranty...lol. I'm not sure what the prob is at this time. My wires and everything is fastened with a small amount of slack so their not getting moved around. All the connections look great also. Customer support didn't help at all....
Later
Graveyard is offline
Old 04-21-2013, 05:06 AM
  #7669
silvalis's Avatar
Trader Rating: 29 (100%+)
tried reflowing your joins and replacing your sensor cable?
silvalis is offline
Old 04-22-2013, 08:48 AM
  #7670
nikos2002's Avatar
Trader Rating: 30 (100%+)
Sorry, been away from the forum a few days. It's been a busy race weekend, will try to put some results up later.
King- you guys are going to like the systems, great to use, smooth, powerful. If you guys have run 8.5 from others before, you might want to add a pinion or two - our current motors are more torque than rpm.
Graveyard- PM if you have any additional question, more than willing to help. It's hard to figure out why a system can cut off, because there are multiple reasons, from different equipment. Sometimes it's a problem, sometimes it's a fluke. PM me if you have more questions.
nikos2002 is offline
Old 04-24-2013, 01:58 AM
  #7671
LosiPRRACER's Avatar
am considering a VTX10 with VST 13.5T sensored setup for my 22SCT.
is anyone still running these with goodluck? they are less then $200 for the combo on Amain.
LosiPRRACER is offline
Old 04-24-2013, 04:28 AM
  #7672
DustinH's Avatar
Trader Rating: 26 (100%+)
I would get an 8.5, but that's me.
DustinH is offline
Old 04-24-2013, 01:27 PM
  #7673
DaveG28's Avatar
Trader Rating: 65 (100%+)
Hi guys,
On the 540 motors, no matter how tight I screw the endbell, I can adjust the timing by hand...it doesn't seem to move during running but it still makes me nervous..is it normal that they are this loose?
DaveG28 is offline
Old 04-24-2013, 01:41 PM
  #7674
Trader Rating: 55 (97%+)
A 13.5 might not be the best bet for an SCT. I like my 10.5 and occasionally I run an 8.5.
13.5 works great in my 2wd buggy.
shagnat is offline
Old 04-24-2013, 03:46 PM
  #7675
nikos2002's Avatar
Losi - they are a great deal for a great unit!! We actually went back and updated the spec on the orange VTX to be as close to the BE unit as possible!!
Dave - we have seen that with some of the motors, if you want to feel safe a drop of CA will make sure to hold it. Generally not a concern, we had a batch that it was reported some did that.
Old 04-24-2013, 05:03 PM
  #7676
our rules at min 10.5 so can either run 10.5 or 13.5
Old 04-24-2013, 05:08 PM
  #7677
AndrewTom's Avatar
the 13.5 should be fine, very controllable, and usable powerband. a 10.5 will be a bit more powerful. once you get down to an 8.5, 7.5, 6.5... you need to be a little more skilled with throttle input.
you can always run boost as well!
AndrewTom is offline
Old 04-26-2013, 08:56 PM
  #7678
nikos2002's Avatar
WOW, really, nobody is around? Must be nitro season.........
Old 04-26-2013, 09:25 PM
  #7679
Jim Hustins's Avatar
Just got home from our last Friday night indoor race. Ran my SC8e on 5s with a 1900kv motor with a Viper VTX8 ESC on a really tight track. It is so smooth. Check it out.
+ YouTube Video
Jim Hustins is offline
Old 04-26-2013, 11:40 PM
  #7680
Really?
shagnat is offline
