Viper RC -
#16
Ok, they are different types of products, but they suppose to work together...in fact many producer offer them as combo just like castle or tekin and many other... If you go buy a car(1:1) and the dealer tell you: the car have 3 years warranty but the motor have only 1 year, what do you think about it? Anyway nothing wrong with 180 days, I was just curios about the difference between motor and esc...
I see your point, just the comparison was a little off
#17
Super Moderator
Trader Rating: 31 (100%+)
[QUOTE=SaladFork;8248083]Nice looking stuff Weylin! Looking forward to the 1/10th ESC's.
And if anyone was asking about preformace of the Viper stuff, I haven't tried anything from them but one of the local racers is sponsored by Viper and is unbeatable, literally walks away in mod buggy every week.
I agree stuff looks nice and this is a nice plug but I'm pretty sure people are sponsored because they're fast, they're not fast because they're sponsored.
#18
Good point Siliro, I like that view point you brought up. On one hand, I would suppose that if the esc and motor were sold separately from each other, the different warranty times would be understandable.
However, as you brought up with your real life 1:1 car warranty example, I was thinking if the motor/esc were sold together "as in a combo package", maybe a blanket warranty time frame (i.e. same warranty days for both in combo package) might work as you suggested.
#21
Let's clarify this warranty discussion to remove any confusion.
Viper R/C Solutions provides a 180-day (6 months) warranty on all motors or other mechanical products.
Viper R/C Solutions provides a 365-day warranty on all ESCs or other electronic items that connect directly to a battery or other power supply.
Therefore, ESC is covered by a 365-day warranty (not 360 day, which was mentioned earlier, that was a typo).
As for the combo warranty, it simply follows our policy. That is the motor belongs to mechanical product, and the ESC belongs to electronic product. The warranty of combo will count on the customer's invoice/ receipt. There wont be any confusion. We are giving customers better protection on their valuable Viper products by offering a longer warranty.
#22
#24
Looking forward to your 1/8 ESC and motors.
I really hope your 1/8 esc's can handle the abuse that 1/8 buggies and truggies place on electronics. I want to be able to land a huge quad with confidence that my esc will continue to work right after and not blow the magic smoke or go out in a blaze of glory.
#25
Tech Legend
Trader Rating: 51 (100%+)
mini dub thanks for taking the time to get back to me. I did run the 17.5 fixed timed motor tonight in my SCT and overall it wasn't bad at all. I found the motor to have a good amount of snap and my laptimes were very close to my normal 17.5 I run. I ran it twice overall with my same settings I use on my other 17.5 that also has about 10 degrees extra timing and it help its own. Laptimes say I was within a tenth so with more time on it I can even make the fixed timing one a little faster so either way I would say these motor run very well. Very nice overall.
Its going to be ineteresting to see what else you guys come up with. Everything The Hidden Hanger has from you guys is pretty cool. Nice that I get to try it out.
Also had another guy try out the fixed timed 13.5 in his dirt oval car and found out that it to was very fast even with no extra timing in the motor. His laptimes again were very good overall. He thought with a little messing around on the speedo he could of made the one test one go as fast as his higher timed 13.5 he normally uses.
#26
#27
#29
do the ESC's have boost similar to what tekin has? a dual drive mode? or are they sensored only based
#30
Tech Legend
Not a problem, glad you got a chance to try the pre-production samples. Sorry those samples had fixed timing, when you get yourself a production motor with fully adjustable timing I'm confident it will outperform your old motor. The timing increase on the motor itself greatly improves the low to mid range powerband, as well as adding some straightaway rpm. Did you guys make sure to gear up from the other motors? Our motors are high watts and have lots of torque, despite being super smooth, so they prefer a taller gear.
The 13.5 guy did gear up just a little so not to get it too hot on its first run or two. After that he added a little more speedo timing and added another tooth or so on the oval and was very pleased with how it ran.
I know Luke will be ordering some of the production versions with the adjustable timing as soon as they are available. If don't know when just let Luke know at The Hanger because he will order some.
