Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-23-2014, 09:21 PM   #1471
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Got to try out my VTX10 in my buggy last weekend and Im pretty happy with it. Going to pick up a VTX10r for my TC soon. Thanks Nick.
Josh-n-ya is offline   Reply With Quote
Old 04-23-2014, 09:32 PM   #1472
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Drerc View Post
I installed my viper today. Very very nice machine. But i have a few questions
first of all. It is installed in an xb4. You have a little bar where the wires go under from escto motor. But with the cables under that and the esc taped on the chassis, The wires and poles are stressed. I don't know if the poles could damaged bend or ruined because of this?
My second thinking about it. The poles are very close to each other. When they're stressed they maybe bend a bit and touch each other? Now it is good and works. But i don't know if when landing a high jump they maybe get a shock and touches each other? Is that possible?
Really wan't to make sure. Because my previous lasted for 3 laps and broke...
Thanks so much !
Hello,
Maybe add some heat shrink to the battery terminal poles. As for the stress maybe try soldering them so they exit at an angle and not straight up?
defcone is offline   Reply With Quote
Old 04-24-2014, 08:57 AM   #1473
Drerc's Avatar
I soldered them in 90 degrees angle, and putted heat shrink around every wire, also at the esc, but could they move a bit from a little shock, or a hard shock? Could they maaaybe touch?
Drerc is offline   Reply With Quote
Old 04-24-2014, 09:03 AM   #1474
defcone's Avatar
I don't race offroad, but on my touring car I've hit the fence pretty hard and haven't had a problem yet. Maybe add some zipties on the wires near the poles to space them out?
Old 04-24-2014, 09:19 AM   #1475
Drerc's Avatar
maybe I could use that
Old 05-03-2014, 04:00 AM   #1476
brighty's Avatar
Hi
I'm using a Copperhead ESC with a HW 4000kv 4 pole. I've measured with my GPS that there is no increase in speed when the timing on the ESC is increased. Are there compatibility issues between the Copperhead ESC, and HW motors? Every other programable item is able to be changed, except timing. I use the viper programming card to change all my parameters.
HPI Savage XS - Viper Copperhead, Viper VX439
Team Associated B4.1 - Hobbywing Xerun V2.1 120A, Hobbywing Xerun 8.5
Xray T3R - Novak Kinetic, Novak Ballistic 17.5
Kyosho Lazer ZX-5 - Speed Passion Cirtix 'Stock Spec', Speed Passion 17.5
Kyosho TF3 - Old Skool 15t brushed
brighty is offline   Reply With Quote
Old 06-04-2014, 04:37 PM   #1477
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
I saw Chris Blakley's blog about WGT 10.5 boosted setups. The info was from a year ago or so for the VTX1 and he was using a rollout of 56mm. Is that still valid?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 06-05-2014, 12:01 PM   #1478
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Yes, since then we have even updated our software (to a64) with one of the primary goals being better operation in boosted format for more efficient operation and less heat build up. But the idea of the settings, etc. is good.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 06-05-2014, 12:11 PM   #1479
nikos2002's Avatar
Originally Posted by brighty View Post
Hi
There isn't any know issues - maybe its just as fast as the motor will go?? If you lower it, does it slow down? Also, I have been told by some people that some GPS systems are not super accurate, so small change might now show up.
Nick Malato
Old 06-05-2014, 08:15 PM   #1480
RAL
RAL's Avatar
Thank you Nikos!
Old 09-03-2014, 04:42 PM   #1481
When do you anticipate the ROAR approval going through for this firmware version? The current ROAR list indicates A55 is the latest approved version.
http://www.roarracing.com/approved_non_timing_escs.php
Thank you.
David
TC, WGT, and 12th
Note: my username is a crossword puzzle clue to my first name. It is not a statement of my abilities as a driver (obviously).
GoliathOpponent is offline   Reply With Quote
Old 09-04-2014, 05:48 PM   #1482
nikos2002's Avatar
I don't want to sound bad in any way -- but we aren't 100% sure its worth the over $1000 price tag it would cost to submit it. Nothing changed on the blinky side of the software from a55 to a64. We don't know the last time that a speed software was checked at an event. Other than to verify blinking light. Not to say we are trying to skirt the rules in any way. Which we are not. But its an awful lot of money to spend to "say" its legal. We'd rather spend the same amount and send more race prizes to tracks holding events.
Nick Malato
Old 09-04-2014, 06:56 PM   #1483
patorz31's Avatar
Viper is one of the few RC companies that support events with great prizes and the racer with simply awesome customer support. I can't argue with Nicks reasons, for not worrying about summiting it to ROAR.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 09-05-2014, 03:11 PM   #1484
nikos2002's Avatar
Just to present a different side of the story. The BRCA asked us to confirm that the latest version was made under established rules, had us agree that we understood sanctions were possible if it was tested otherwise. We agreed, it was updated on their site over a weekend and published.
Nick Malato
Old 09-05-2014, 07:33 PM   #1485
Thank you for clarifying. I was considering traveling to events that uses ROAR approvals and did not want to run into issues if teched (or challenged).
David
TC, WGT, and 12th
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
