Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 05-28-2013, 04:23 PM   #1381
silvalis's Avatar
Trader Rating: 29 (100%+)
Is there a new black edition VTX1?
Also, any specific reason for the VTX1 over the 10 for these classes? Just what they had?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-29-2013, 01:25 PM   #1382
nikos2002's Avatar
Send a message via AIM to nikos2002
Little lighter weight. In the ARC cars these guys were running is little on the heavy side in its current form so, saving a little with the esc helps.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 06-25-2013, 04:37 PM   #1383
I want to run a vtx1 and a 17.5 in my 12r5 where should I start with gearing? I will be running 1cell.
getting out of RC
MikeFrazer is offline   Reply With Quote
Old 06-25-2013, 09:11 PM   #1384
pcar951's Avatar
Trader Rating: 19 (100%+)
Depending on motor and physical timing - roll out = 72-78 blinky/64 boosted. Should get you in the ball park.
Jim C.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 06-25-2013, 10:09 PM   #1385
Running the vst17.5 I was thinking blinky not boosted.
getting out of RC
Old 06-25-2013, 11:51 PM   #1386
pcar951's Avatar
With the vst 17.5 blinky you can gear for slightly lower roll out and add physical timing. You can actually get around 50 degrees of end bell timing but be sure to check temps. I think I found the best performance around 40-45 degrees and around 70 roll out with the stock rotor.
Jim C.
Jim Chapman
Old 06-26-2013, 10:29 AM   #1387
nikos2002's Avatar
Thanks for the help Jim!!! Nick/Viper
Nick Malato
Old 07-09-2013, 11:00 PM   #1388
Pan car just seems slow with the 17.5 but I did not have the timing up enough. Try it again next time at the track. What should my setting be on the speed control also I want to run a vst 21.5 in my tc6 and will need assistance with that also. Is anyone sponsored by Viper running in the northwest asphalts challenge? Thanks in advance.
getting out of RC
Old 07-09-2013, 11:27 PM   #1389
JayBee's Avatar
Trader Rating: 31 (100%+)
Trying to cut shrink wrap off of my speedo, I nic'd the on/off switch wires. I wonder if Viper can fix this?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-10-2013, 12:21 AM   #1390
pcar951's Avatar
Don't be afraid to crank the end bell timing, 1S is pretty easy on motors. For me, I feel like I'm getting the best out of my 1 /12 - 17.5 motor in blinky when it's coming off at about 130 degrees after 8 minutes.
I don't run 21.5 myself but the local racers that run them in VTA really seem to push end bell timing to the limit. I've seen some ridiculous motor temps at 4.2 FDR! I can tell you that the VST's don't like to see temps past 165 degrees so, be sure to monitor temperature.
Jim C.
Jim Chapman
Old 07-10-2013, 12:27 AM   #1391
pcar951's Avatar
I'm sure if you sent it in Viper could replace the ribbon cable, Nick could better answer the question.
Did you cut through the wire or just the insulation?
Jim C.
Jim Chapman
Old 07-10-2013, 12:49 AM   #1392
Thanks Jim. Where can I look at speed control settings? So try to keep temps about 160 or get a fan
getting out of RC
Old 07-10-2013, 01:36 PM   #1393
JayBee's Avatar
Jim C.
Unfortunately the blk/brn/red wires
Old 07-10-2013, 02:31 PM   #1394
nikos2002's Avatar
JayBee - check your PM
Nick Malato
Old 07-17-2013, 01:10 PM   #1395
I'm running "mod" (10.5 boosted), and I want more brakes.
Rough setup (a couple things might be off by a hair, since I'm doing this from memory).
Car is on the heavy side (~1420-1440g)
Novak Ballistic 10.5
Motor timing at "N" / 30
FDR 6.5
VTX10
8000-25000 30*
15* top speed timing (don't remember rate)
Brake Freq: Tried everything from ~2000-9600
Brake Strength: Tried from 70-100%
Drag brake: tried 0 to 50%
Dynamic brake: tried disabled and 30 max / 15 min / 15000rpm / linear
The power feels fine, good throughout the power band, nice and smooth, and no temp issues. The problem is the brakes just feel really, really weak at high speeds. Anything over about 25% of top speed, and the car barely feels like it slows down at all. Then when the speed comes down, the brakes are suddenly really, really strong. I can use the dynamic brake to smooth out the low speed braking for corner entry, but the real problem is the high speed braking. I have to lift and start braking so early I'm losing a lot of time.
The only idea I have left is to try a higher (number) FDR, but then I'll have to retune the whole power side of the equation.
Anyone have any suggestions?
-Mike
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
