Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-25-2013, 10:12 PM   #1366
M3Roc's Avatar
Trader Rating: 108 (100%+)
Wish I had a VTX1... The VTX10R needs a 2s battery to run normal.. I don't have room to fit a booster or receiver pack and I can't add the extra weight or either.. It sucks too because I paid over $250 for the setup and can't even use it.. Nice setup you've got BTW. I like a clean setup.
On the other hand, if Viper is willing to help me out here, I would be forever grateful! I however, don't think they are interested because Ive soldered new wires on already. Lets hope it sells soon so I can use the money and get back to racing..
☆ What a wicked web we weave, when first we practice to deceive. ☆
☆ Wolves don't lose sleep over the opinions of sheep. ☆
☆ Life never favored weakness, Only the strong survive. ☆
M3Roc is offline   Reply With Quote
Old 04-28-2013, 12:23 PM   #1367
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Sorry you purchased the wrong system, the 1s - 2s difference is stated about as clear as we can make it.
We have a trade in program if you have out of warranty equipment, but don't think the option quite applies in this case.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 05-02-2013, 02:57 PM   #1368
Ciao Nick,
do you have any news concerning the new motor???, any photo to show us???
how long time i must still wait???
Ciao
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 05-02-2013, 05:36 PM   #1369
M3Roc's Avatar
Its no worries really. I traded the ESC and motor for an F104 and a TC1030.. Ill still hang onto my 17.5 viper motor to keep as a backup but I mostly run Thunder Power now.
Old 05-02-2013, 11:04 PM   #1370
nikos2002's Avatar
Originally Posted by mtaddei View Post
Ciao Nick,
Ciao
Max
New 540 motors should be here in June!!! We are making all the tooling for production right now. Very excited, can't wait to show everyone!!!
Nick Malato
Old 05-03-2013, 05:46 AM   #1371
Awesome, can't wait get my hands on them!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 05-03-2013, 08:04 PM   #1372
nikos2002's Avatar
Mark Smyka's VTX1 is handling the heat down in FL at the On Road Nats. Hearing track temps are up towards 120F today!!!!!
Nick Malato
Old 05-05-2013, 08:57 PM   #1373
nikos2002's Avatar
VTX1 helps propel Mark Smyka to a complete sweep of the 1/12 17.5 class at the ROAR Nationals. TQ's all four rounds of qualifying, wins the first two A Mains to clinch the title.
VTX1 completes the ROAR sweep in Smyka's hands winning both ROAR Nationals in the 17.5 class. Small stance, no booster needed, easily programmed, capable to run spec or modified classes, ProGauge for quick adjustments -- all items that helped Mark win 2 National Championships, a win at Snowbirds (F1), A Main finishes at IIC and Snowbirds.
Pretty potent little device to run on road spec classes..... and more......
Nick Malato
Old 05-20-2013, 06:36 AM   #1374
No9
No9's Avatar
Fixed the issue thanks for all the help.
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
Old 05-20-2013, 09:33 AM   #1375
smyka's Avatar
Send a message via AIM to smyka
No9 your post is very confusing one time you say it wont calibrate then next you say it will ? are you talking about two different speedos ? also when you pust the button to calibrate you hear the noise and pull full throttle do you push the button again to save the setting ?
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 05-20-2013, 11:50 AM   #1376
Trader Rating: 15 (100%+)
Power on speedo by holding for three seconds and it will go into calibration mode. Hold full throttle, press button. Hold full brake, press button again. ESC will power cycle and you should be good to go.
Where exactly in this procedure are you having the "pull full throttle and nothing happens" problem? The motor will not receive power during calibration, if that is what you are referring to?
Also, make sure your throttle and brake are at 100% when doing the above. I had an issue at carpet nats that Mark (Smyka) had to help me with where I had my throttle set to 100 (I had forgotten that max is 150 on KO) and the speedo wouldn't calibrate. Seemed like it wouldn't find neutral correctly.
If you also ever have an issue where your speedo won't turn off when you hold down the button, you should recalibrate the speedo to your radio and it should fix the problem.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 05-20-2013, 01:38 PM   #1377
nikos2002's Avatar
Calibration video:
http://www.youtube.com/watch?v=H3FfFS-mThk
Nick Malato
Old 05-20-2013, 04:13 PM   #1378
No9
No9's Avatar
Massive mistake on my behalf i was at fault and i am deeply sorry for my original post and will edit it now .Agian sorry Viper r/c im an idiot .
Old 05-20-2013, 04:20 PM   #1379
nikos2002's Avatar
One thing we have seen is that if the system can not find the neutral point on the radio, it will have a hard time calibrating. Couple of things to try (in no order):
- re-bind TX and RX
- select different model on radio
- verify end points at 100 for throttle and brake (0 expo)
- move throttle trim few clicks up or down
Nick Malato
Old 05-28-2013, 04:13 PM   #1380
ekim628's Avatar
VTX1 Black Edition helps propel 2 drivers into the 13.5 Expert Stock A-Main @ 2013 Reedy Race of Champions. ESC was powerful and smooth throughout the whole run. Once the new motors become available and ROAR approved, we have room for more quicker laptimes. Keeps getting better by the day!!
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
