Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-19-2012, 04:20 PM   #1171
My problems with the throttle "glitch" seems to be solved. I guess it was the change of deadband from Narrow to Middle that did the trick!
Sponsored by Maclan Racing
1:10 Xray XB4 - Viper VTX10R BE & VST 7.5 | 1:10 Yokomo YZ2 - Viper VTX10 & VST 8.5 | 1:8 HB Ve8 HHH - Viper VTX8
macke is offline   Reply With Quote
Old 10-19-2012, 04:22 PM   #1172
Default Question about motor protection
Run my VTX10/VST 7.5 today, indoor on carpet in a TLR 22 geared 76T/20T. It was about 75 F ambient air temp and the track was very technical with lots of throttle and brake.
One time the motor protection hit. Don't remember what the ESC protection setting was set at (could have been 200 F...) but I measured the temp on the motor can and got about 80 C (around 180 F). How big of a difference is it between motor can temp and internal temp?
Also, the data sheet for the VST motor says you should never run the motor above 180 F. Is that can temp or internal temp? If it is internal temp I'm afraid I have been way above the limit... Hopefully I haven't weakend the motor, that would really suck...
I also have a question about how the protection is working when switching the ESC on. When the motor was around 180 F I switched the ESC off and let the ESC and motor cool down. However, I could not turn the ESC on without getting the two blinking leds (motor protection indicator) until the motor can temp was below 120 F. Is that the correct behaviour? Is it possible that the internal temp still was above the threshold even though the can had been pretty much cooled off.
Another thing. Please have a setting where you can switch between Fahrenheit and Celsius in the next firmware. For us Europeans it almost impossible to translate the temps in the head... Seriously, that would be a great feature.
Old 10-19-2012, 05:03 PM   #1173
Trader Rating: 217 (100%+)
Now you know how us Americans felt when things come out ready in "C"! lol
Andy Koback is offline   Reply With Quote
Old 10-19-2012, 06:47 PM   #1174
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
macke - glad to see you got it running - if you want there is more detail in off road section........
To answer some of your questions. The motor protection is read through the sensor connections. So there could be a 50 to 60 difference from what you read with a temp gun on the can. You can increase it - I normally run 220-230 for mod motors.
Yes, you want to keep the motor temps on the can under 180, lower if possible. One time at that temp shouldn't have hurt the motor.
Yes, again, because it read the rotor temp inside the motor, if you turn off the esc and turn it on, it will still show the cut off warning.
As for the C and F readings, I will suggest it, you never know.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 10-19-2012, 11:19 PM   #1175
Trader Rating: 38 (100%+)
I'm running a VTX-1 in my 12th scale using a 13.5 in blinky racing. The ESC seems to work great but it is certainly lacking brakes at this time. I believe the initial profile had the strength at 80% and I bumped it up to 100% after the first run with very little difference in feel. Is there anything else I should be setting to get more out of it or is this just the way it is?
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-20-2012, 12:17 AM   #1176
hyperSC82's Avatar
I have a vtx10r be with a vst 17.5 in my xray t3 and was looking for a non boost set up. Thanks.
Team Durango DESC410 - Viper VTX10R BE, VST550 4.5
hyperSC82 is offline   Reply With Quote
Old 10-20-2012, 02:14 AM   #1177
I sure do...
Hmmm.. I totally missed that thread! OMG another 384 pages to read!
Ok, I guess you are taking about F temps here (50 to 60). So you are basically saying that setting it to 220 F should be a safe setting for the VST 7.5?
I will try to give the motor a little bit more air. I guess if you run the motor to say 175 F (can temp) and then switch it off. If you then try to start it 5 min later the temp in the motor may actually be above the temp it had when you switched it off and may also be above the set threshold.
Great! I can assure you it would be greatly appreciated by many non US people.
Old 10-20-2012, 03:08 PM   #1178
nikos2002's Avatar
Celebrate the Grand Opening of the Official Viper Shop, Get 10% off Everything and Check out the Limited Time Free Shipping Program!!!!
www.shopviperrc.com
Nick Malato
Old 10-21-2012, 08:37 AM   #1179
Luppi Stefano's Avatar
yesterday great work for Viper R/C Italy
test with VTX10R and 4.5 - 13.5 VST on TC car
very fast and easy to drive, amazing how you can change the personality of this ESC!
temperatures always normal!
VST Motor, are fast, low temperatures and a lot of torque
congratulations on the products!
we will try vtx1 early in F1 class
10-11 November we have italian Nat, 1 driver in mod, 1 driver in stock 13.5 Blinky, 3-4 driver in F1 class
we are very confident to bring home good results!
here base setup for 13.5 blinky, but we can work a lot
Viper R/C Solutions - A New Line of Innovative Power systems!-0001.jpg
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-22-2012, 02:36 PM   #1180
ekim628's Avatar
Linkless-
Try lowering the Braking Frequency, this will give you more agressive brake feel and allow you car to stop faster.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 10-22-2012, 02:37 PM   #1181
ekim628's Avatar
Thanks Lupi and congratulations on your sucess in Italy. Your setup looks good and will we post it on our website for other Viper users to try
Eric
Eric K.
Old 10-25-2012, 06:55 AM   #1182
Has anyone used a reedy sonic with the VTX1?
I will be running boosted 10.5 1 cell WGT car.
Couldn't get a viper motor here in time sorry!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 10-25-2012, 04:35 PM   #1183
nikos2002's Avatar
much respect for Mr. Reedy I learned a lot from him years ago when I ran for Reedy. If you couldn't get one of ours, its a darn good choice.
Shouldn't have any issues.
Nick Malato
Old 10-25-2012, 05:18 PM   #1184
defcone's Avatar
Trader Rating: 15 (100%+)
When you guys ran modified, was there a need for an esc fan?
defcone is offline   Reply With Quote
Old 10-25-2012, 07:25 PM   #1185
silvalis's Avatar
I had to put one on my mod tc - esc kept thermalling. I didn't drop the throttle pwm though (was still on 16khz)
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
