Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-14-2012, 12:26 PM   #1156
theatriks's Avatar
Originally Posted by GoliathOpponent View Post
Hello,
You need to go into Misc Control/Run Mode and change it from Race Blinking. The Motor Power settings cannot be set as long as it is in Race Blinking mode. Race Open allows the Motor Power settings to be changed, but disables reverse. Practice mode also allows reverse.
Regards,
Thanks dude and beleive me i was reading the instructions and couldnt find this anywhere...thanks again.
theatriks is offline   Reply With Quote
Old 10-14-2012, 05:10 PM   #1157
You're welcome. Sorry, I cannot help you with your other setup question. I only run in blinky mode.
David
TC, WGT, and 12th
Note: my username is a crossword puzzle clue to my first name. It is not a statement of my abilities as a driver (obviously).
GoliathOpponent is offline   Reply With Quote
Old 10-14-2012, 05:25 PM   #1158
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
theatriks - check your PM
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 10-16-2012, 02:33 PM   #1159
I have had some troubles with my VTX10 to not respond on throttle for a brief moment when the car is turned back on its wheels when it has been on the roof. It's kind of like the delay you got when using reverse and then immediately try to go forward.
I have calibrated the ESC numerous times but the problem still seem to be there, very intermittent though.
I have performed the PPM monitoring suggested on the Facebook page:
https://www.facebook.com/notes/viper...42432302493991
My result are the following
When TX set to 70/30 throttle mode (this is the mode I always use):
F = 1151 us
N = 1647 us
B = 1944 us
If I switch the TX to 50/50 throttle mode i get:
F = 1102 us
N = 1498 us
B = 1893 us
I get the same readings every time I try so the radio seems to be very consistent on the output.
I run the VTX10 with Narrow dead band. I first suspected that it was my neutral not going back correctly and maybe the trigger gave a little bit of reverse when in neutral. But that does not seem to be the case. When using the PPM monitor the trigger always return the exact same neutral value (i.e. 1647 us) when releasing the trigger.
This will probably not be a problem when racing because the reverse is not allowed, but it is very annoying when practicing for sure. Please give me some advice.
BTW, the TX is a Airtronics/Sanwa MT-4 with a 451R receiver.
Sponsored by Maclan Racing
1:10 Xray XB4 - Viper VTX10R BE & VST 7.5 | 1:10 Yokomo YZ2 - Viper VTX10 & VST 8.5 | 1:8 HB Ve8 HHH - Viper VTX8
macke is offline   Reply With Quote
Old 10-16-2012, 02:37 PM   #1160
defcone's Avatar
Trader Rating: 15 (100%+)
F = 1151 us
N = 1647 us
B = 1944 us
F = 1102 us
N = 1498 us
B = 1893 us
Do you have normal mode selected with the throttle?
defcone is offline   Reply With Quote
Old 10-16-2012, 04:01 PM   #1161
I'm not sure what you mean?
Old 10-16-2012, 07:43 PM   #1162
nikos2002's Avatar
Anytime something seems fishy with electronics - check your sensor cable. Make sure its plugged in or take it off and try another. The esc reads the end points from the radio, so something is happening here.
Is there a mode that gives you 100/100 throw on the forward and brake - what ever is stock on the radio's software.
Then its also all the little things, connections on the receiver, no wires pinched or shorted, solid connections. Even try different model within the radio as each can be a little different (you can also check that with the PPM test).
Nick Malato
Old 10-16-2012, 09:39 PM   #1163
defcone's Avatar
At the bind menu, does the TH say normal?
Oh be sure to set the mode at FH3.
Old 10-17-2012, 01:09 AM   #1164
The RX is bound in FH3 mode. The throttle channel is set to normal mode and the steering to SHR mode.
Old 10-17-2012, 01:14 AM   #1165
defcone's Avatar
Then I have no idea hahaha, try reflashing the software in the speedie maybe?
I have the exact same combo as you and don't have this problem.
Old 10-17-2012, 01:26 AM   #1166
Ok, I will test another model in the radio and see what readings I get. I do have have the throttle EPA set to 100% in the radio and the calibration process is not an issue. I also get the solid lights on the VTX10 when appying full throttle and brake. This is why I suspect this has to do with the neutral.
Could it be that my neutral is too near the 1700us upper limit? If I get the same reading on other model memories would it not be possible to use the throttle subtrim to adjust it down so neutral is say 1600us? Just speculating now... I would rather not use the 50/50 setting in the radio because of the less forward resolution.
I have no idea what the real problem can be. All connections are solid (good soldering etc) and the sensor cable is brand new. (I do have another one, maybe I will try that one as well)
Old 10-17-2012, 01:28 AM   #1167
BTW the software is what came with the unit, A30.
Old 10-17-2012, 01:48 AM   #1168
defcone's Avatar
Yeah try upgrading it.
Old 10-17-2012, 12:46 PM   #1169
nikos2002's Avatar
macke, I also answered your post on the Viper forum if you want to check there....
Nick Malato
Old 10-17-2012, 03:47 PM   #1170
mdwalsh's Avatar
Trader Rating: 26 (96%+)
if anyone is looking for a viper VTX10 ive got one for sale it comes with the fan unit, pro-gauge, and the pc-link....pm me for details.
Matt
mdwalsh is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
