Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-10-2012, 03:29 PM   #1141
ekim628's Avatar
Luppi- Glad to hear it's working for you now. If you have any more questions let me know and I will help you.
Also the IIC setups will be posted today or tomorrow on this forum and our website. Please stay tuned
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 10-10-2012, 09:43 PM   #1142
so i have a tough one for you guys to figure out, i ran my 12r5.1 with a viper 17.5, so long story short by the end of the night i was running a rollout of 102 and maximum acceleration and top speed boost and my motor only came off after 8 mins at 115 degrees! no joke!
i still need a setup for 17.5 boosted though cuz i still need speed?! thanks in advance
Team Associated SC10- LRP - Viper VST10.5
Losi SCTE - Viper VTX10R - Viper VSTXL 4.5
Savage XL - Dynamite Big Red .28
Viper RC - MIP - PM Hobbycraft - Pro-Line - Spektrum
calo247 is offline   Reply With Quote
Old 10-11-2012, 11:08 AM   #1143
Luppi Stefano's Avatar
in my opinion Viper VST Motor is the best on market, really!
VTX10R, I have to try better, but even with 13.5T I love it, Blinky and Boost!
I can't wait to try it with the new Mt-4 and 4.5T...
really compliments!
p.s. I have a little question about Optional ESC Fan, it start a definite temperature, or not? (what temperature you have set?)
...because mine has never turned...
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-11-2012, 01:32 PM   #1144
ekim628's Avatar
Hmmm, thats sounds too cool. I dont know anyone running boost 17.5 in 12th scale anymore but i would try different rollout, maybe 120 and increase the boost timing to 40* and max acceleration timing to 35*
For the RPM start and finish it should be around 3,000 start 12,000 depending on the track layout and straight length
Eric K.
Old 10-11-2012, 01:33 PM   #1145
dski's Avatar
Looking at the setup sheets from IIC, A30 was run in blinky class. What is the reasoning to not run A55?
dski is offline   Reply With Quote
Old 10-11-2012, 01:36 PM   #1146
ekim628's Avatar
Well Luppi, if you attached the fan directly to the port on the back of the ESC, it should turn on when the esc is turned on. I usually hook up my fan directly to the positive and negative terminal on the esc so it runs off battery power at 7-8 volts, much stronger than running from BEC voltage
Let me know if it still doesnt work
really compliments!
thanks
Eric K.
Old 10-11-2012, 01:40 PM   #1147
ekim628's Avatar
Setup sheets from the Exciting IIC Indoor Carpet Championships are up on Viper's Website http://www.viper-rc.com/vtx1.php
Josh's 12th scale MOD setup
http://www.viper-rc.com/uploads/setu...9d8f789a53.pdf
Josh's winning 10.5 Expert WGT setup
http://www.viper-rc.com/uploads/setu...0599d83cf4.pdf
Mark Smyka 17.5 Non Boost 12th scale setup
http://www.viper-rc.com/uploads/setu...0d1c4082a5.pdf
Eric-
Eric K.
Old 10-11-2012, 03:08 PM   #1148
Those rollouts don't seem right for a 17.5 boosted. I think 17.5 blinky at paved nats was up around 120mm with their huuuuuuuuuge straight. In 13.5 blinky on 100x50' carpet, we were running 85-90mm, and I'd expect you'd want to be at least that low for a boosted 17.5.
I'm betting you're not getting the motor RPMs up high enough to even get your boost and top speed timing to kick in. What are your settings?
-Mike
Old 10-11-2012, 04:15 PM   #1149
connected to the battery, not works!
I change from mikimodel
Lab F1-01
Old 10-11-2012, 04:26 PM   #1150
-Mike
i tried a 75mm roll out the week before and i could not keep it under 180 even with no timing
Old 10-11-2012, 05:56 PM   #1151
ekim628's Avatar
Well A30 and A55 is identical in spec blinky mode. Nothing has really changed except the boost and advanced timing parameters. We wanted to follow all the rules set by the IIC crew so it was safer to run A30.
Eric K.
Old 10-13-2012, 09:23 PM   #1152
theatriks's Avatar
Hey guys anybody have a good starting point for 17.5 boosted ...first time with a viper vtx10....any settings help would be appreciated....thanks.
theatriks is offline   Reply With Quote
Old 10-14-2012, 11:00 AM   #1153
theatriks's Avatar
ANYONE?.....how do you set boost on this damn thing!!!!VTX10.....ITS saying invalid mode when i try to get into the motor power section of the menu.......i have never had a speedo give me as much trouble as this damn viper!
Old 10-14-2012, 11:34 AM   #1154
Well most 17.5 racing in the US has gone to blinky mode so it may be a little while before you find someone with a boost setup.
Old 10-14-2012, 12:19 PM   #1155
Default Setting Motor Power Settings
Hello,
You need to go into Misc Control/Run Mode and change it from Race Blinking. The Motor Power settings cannot be set as long as it is in Race Blinking mode. Race Open allows the Motor Power settings to be changed, but disables reverse. Practice mode also allows reverse.
Regards,
David
TC, WGT, and 12th
Note: my username is a crossword puzzle clue to my first name. It is not a statement of my abilities as a driver (obviously).
GoliathOpponent is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
