Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-06-2012, 07:48 AM   #1126
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
It's been a busy couple of days at IIC.
josh put down an amazing run to TQ the 10.5 World GT class. He built a radical new 1/12 car set up to try in the last qualifier - it has amazing steering, maybe a bit too much. And unfortunately it was a rocket round so he dropped to 5th in 1/12 mod. And he is currently 10th in Mod TC
Mark qualified 3rd in 17.5 1/12. Pretty awesome since he was knocked out of the A Main during the rocket round and had to fight his way back in.
It's been an awesome week. Looking forward to some great heads up racing today.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 10-06-2012, 09:37 AM   #1127
good to hear the viper products are doing well!!
Good luck to everyone in the finals
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 10-07-2012, 12:56 AM   #1128
nikos2002's Avatar
Thumbs up
WOW what a great week at IIC. We had a great showing, learned a lot, had a good time as well.
Huge thanks and congratulation to Josh. It was great working with him. The way he just checked out in WGT was awesome. Only working with us for 1 month, it's been great. Can't wait to see what's next.
Smyka had an awesome run in 17.5 1/12- we had as off of the lead there. Close all week, right on pace, his cut though the sweeper so well
Great meeting the customers there using our stuff, we learned a lot and will try to post set ups once we get home and get a little rest.
The futureis getting brighter al the time..........
Nick Malato
Old 10-07-2012, 01:50 PM   #1129
Luppi Stefano's Avatar
I have some coggin Problem with Vtx10r / VST 4.5T, this problem is at full throttle, motor cut cut, release and I give it slowly no problem...
I had problems with dispensing, I touched a little bit all the parameters, but haven't found a solution...
the problem may be that I'm using a Sanwa M11 40Mhz?
I Haven't Problem with 13.5 VST
below setting used for 4.5
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-08-2012, 09:44 PM   #1130
nikos2002's Avatar
Ciao Luppi,
To confirm you are running in blinky mode (no boost) with the 4.5? what is the timing on the can set at?
I would like Punch down slightly, but you already have it low. Josh was running a much more aggressive profile with a 3.5 and 4.5 boosted this weekend at IIC with no cogging issues. Also is it a consistent cog or just at low speed?
Nick Malato
Old 10-09-2012, 10:18 AM   #1131
Originally Posted by nikos2002 View Post
Ciao Luppi,
I do not remember having used in blinky mode, only open setting, but 0 max timing in acceleration and top speed
I try 15 and 30 on motor
almost undriveable with littl coggin on mixed, unpredictable and consistent coggin on the straght, with interference on steering servo...
I try blinky mode maybe?
change radio?
thanks
Lab F1-01
Old 10-09-2012, 11:54 AM   #1132
Hey Nick, Great to meet you at the IIC and thanks again for all your help! I learned quite a bit about the ESC last week
Perhaps Luppi has the same issue I had where it acted like the sensors were not working. One of my solder joints on the motor or ESC wasn't good and the effect looked just like a bad sensor. Try re-soldering your motor wires.
Old 10-09-2012, 02:56 PM   #1133
hi!
I think I can exclude the solder cables, because it was rebuilt two times.
but thank you for the help!
certainly try again to solder everything perfectly
Lab F1-01
Old 10-09-2012, 03:52 PM   #1134
ekim628's Avatar
Originally Posted by Luppi Stefano View Post
hi!
Hi Luppi,
Try checking the receiver power, sometimes the receiver cannot handle large amounts of power dumping into the ESC. If the receiver is browning out and causing voltage cut-off it can lead to cogging feel. Also check the sensor cable and sensor pins, usually those can go bad even if they are new. If your using boost i would highly recommend not using it with a 4.5 motor, too agressive and it can hurt more than help. Try using race blinky and use the gearing and endbell timing to up the speed. Let me know if this works out for you
Eric Kim
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 10-09-2012, 03:55 PM   #1135
ekim628's Avatar
One more thing you can try, go into the proguage and set the voltage cut-off to the lowest setting.
Eric Kim
Eric K.
Old 10-10-2012, 03:00 AM   #1136
wkl
change radio?
thanks
What is your slew rate for top speed?
wkl is offline   Reply With Quote
Old 10-10-2012, 08:15 AM   #1137
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Settings
Will the IIC setting's from the Viper team drivers be posted on Viper's website soon?
Just trying to figure out a baseline for 17.5, 13.5, and 10.5
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 10-10-2012, 08:49 AM   #1138
defcone's Avatar
Trader Rating: 15 (100%+)
Slew rate doesn't matter if there's no turbo timing.
defcone is offline   Reply With Quote
Old 10-10-2012, 09:48 AM   #1139
smyka's Avatar
Send a message via AIM to smyka
i know me and josh sent in what we were running so i would imagine they will be posted asap
mark
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 10-10-2012, 10:32 AM   #1140
thanks all!
Thanks Eric!
I think it's the fault of old rx!
I bought a new radio, Sanwa MT-4, I think to resolve all the problems!
I will tell you soon if everything is ok!
Lab F1-01
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
