Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-19-2012, 08:21 PM   #1081
Originally Posted by nikos2002 View Post
I forget the name of the company (bought at stormer), but it's just the pins. You can shorten the wire and put on new pins. Just re-apply the plug.
That's fine for shortening the lead...but doesn't work for lengthening it. I went and bought the good crimper from Servo City to be able to properly crimp pins onto the lead so I'm set for shortening it...but sometimes the lead gets beat up and needs to be replaced or we move it to another car where the longer lead is needed again.
I do think it is great how long the lead already comes for the Viper. It made it easy to install in my WGT car without having to use an extension.
Old 09-19-2012, 08:33 PM   #1082
Hey guys,
Been on the fence on changing esc. for the coming up indoor winter season.
I presently use a tekin rs. 90 % or our club does too.
I've alway like to use new and different brands. to see what the difference might be.
Ive been watching viper on the sidelines, for awhile and see what it all about.
We race only 12 scale 17.5 boosted here. We have 3 to 4 heats. So 12 scale is a live here.
my question how does and would this esc keep up with the tekin with boost.
cheers
cyrrus is offline   Reply With Quote
Old 09-19-2012, 10:54 PM   #1083
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
question should be how do they keep up with us
Seriously - excellent boost and timing functions and performance, tremendous options for your adjustment.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 09-20-2012, 07:34 AM   #1084
I forget the name of the company (bought at stormer), but it's just the pins. You can shorten the wire and put on new pins. Just re-apply the plug. As has been mentioned by others, that doesn't help when you need to go back and lengthen the wire again. Yes, you could go back and add an extension to your shortened wire, but that's hack and just adds another point of failure.
Sensor wire question- never looked at it as an issue. How often are you replacing sensor wires? I very rarely replace them (my experience). It's not a matter of how often, it's a matter that WHEN it needs to be done it's a pain in the ass compared to other ESCs that place it on top where it's easily accessible.
ProGauge question- the idea of the ProGauge was so you didn't need a whole computer set up to make the adjustment, and it could be done quickly trackside. Adding batteries making it bigger, complicates the work and the process (what if that battery dies?). If the battery dies, you failover to working off of the car's battery. I'm not talking about strapping a 12v deep cycle battery to the Pro Gauge. I'm talking about a small, 3v lithium button cell here. I'm sure there's plenty of extra room inside the Pro Gauge casing for one. Increased size should be a non-issue. By your logic, mechanical calipers would be far superior to a digital pair simply because the battery in the digital pair will eventually die. It's called "replacing the battery", and it's not difficult.
Thoughts in red.
Serzoni is offline   Reply With Quote
Old 09-20-2012, 07:38 AM   #1085
Speed wise, they're about the same. The Viper has the advantage of not requiring a booster or receiver pack though. That's the only reason I'm using them in my pan cars vs a Tekin. With the A55 firmware update, you lose a little bit of adjustment over the Tekin in regards to boost, but once setup correctly they're still competitive.
Old 09-21-2012, 08:40 PM   #1086
Dog Bone's Avatar
Can somebody share their ESC settings for 17.5t VST boosted for 1/12 scale (VTX1, preferably A55)? I'd also like to know what rollout you're running, as well as end-bell timing.
Thx!
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 09-22-2012, 10:44 AM   #1087
nikos2002's Avatar
Ken, I answered some of your questions with the email. Nick
Nick Malato
Old 09-22-2012, 07:55 PM   #1088
Jordan Anderson's Avatar
Oops, wrong thread...
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Last edited by Jordan Anderson; 09-22-2012 at 08:16 PM. Reason: ... meant to put this in the Viper off road thread...
Jordan Anderson is offline   Reply With Quote
Old 09-23-2012, 08:56 AM   #1089
Well finally ran the car with the new VTX1 last night.....and I love it!!
Got some settings to start off with from a fellow VTX1 owner Kev Creaser and worked from there. No other GT cars to compare against and I was in a heat with cars running 1s 13.5 blinky but still managed to put in some quick laps. My quickest was less than a second that one of the top guys in the county racing 1/12ths running a mod motor!
One small thing I noticed though was that when the boost kicks in on my motor it makes quite a click in the motor (this is just revving it up on the bench). I am not sure if I noticed it on track or not but just something I would mention.
Also should I be concerned about the speedo getting up to about 42degreeC after a race? Or is that just the casing doing it job and getting rid of the heat from the actual components?
Can't wait to get back to the track again!!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 09-23-2012, 12:48 PM   #1090
Dog Bone's Avatar
Got some settings to start off with from a fellow VTX1 owner and worked from there. No other GT cars to compare against and I was in a heat with cars running 1s 13.5 blinky but still managed to put in some quick laps. My quickest was less than a second that one of the top guys in the county racing 1/12ths running a mod motor!
Can you post your settings for the rest of us, including rollout? I tried all sorts of things last night in 17.5 1/12 boosted, and I was still *way* slower than the other cars running Tekin's. Very frustrating.
Ken Miller
T4 2015
CRC Twenty5
Old 09-23-2012, 01:02 PM   #1091
nikos2002's Avatar
From the email you sent me the other day, did you lower your start rpm (down to 1000). What is your rollout. The guys testing for IIC are around 94-95 at the track they are testing on - but that is blinky 17.5. Just didn't know if it would help you to know that. Ken check your PM.
Nick Malato
Old 09-23-2012, 01:05 PM   #1092
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Set-up
I run 12th scale and just installed the VTX1.
Is there a link or forum on the Viper website that has set-up's for 17.5, 13.5 and 10.5?
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 09-23-2012, 01:16 PM   #1093
Dog_Bone, I will do when I use my laptop tomorrow, saved the settings on there. I was running WGT 10.5 boosted though so don't know how much use they will be. I don't know much about 17.5 boosted 1/12th sorry.
Nick any theorys about my questions in my previous post?
Old 09-23-2012, 05:02 PM   #1094
nikos2002's Avatar
I wouldn't worry to much about esc heat in 1/12. That case is just pulling hear from the board. If there was a real heat issue the cut off would kick in.
PM me your settings. Don't know why there would be a click sound.
Nick Malato
Old 09-24-2012, 03:15 PM   #1095
settings PMed to nick but here they are for anyone else:
Running WGT 10.5 boosted. Trinity D3 motor with about 5 degrees ish on the motor.
52mmpr
BRAKE
Strength 80%
PWM Freq 2500hz
Linear
Throttle
pwm freq 3200hz
punch 100%
curve linear
band narrrow
MOTOR POWER
start rpm 3000
finish rpm 11000
Max timing 30
TOP SPEED TIMING
Slew 8
Max timing 15
Again thanks to Kev creaser for these
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
