Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-27-2012, 09:35 AM   #1006
Jochim_18's Avatar
does this require receiver pack or external BEX to use on 1/12 Application?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-27-2012, 01:45 PM   #1007
The VTX1 is ready to go for 1S out of the box, no booster required.
-Mike
Old 08-27-2012, 03:01 PM   #1008
ekim628's Avatar
Yes the VTX1 is the one your looking for. It supports 1-2 cell without any need for booster/receiver packs. And the foot print is small so it can fit in tight places.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 08-28-2012, 05:38 AM   #1009
Default VTX10R with 4.5T Speed Passion MMM motor
Hi People,
I have recently bought Viper VTX10R esc & running with factory default settings.
My car is Xray T3 '12, Viper VTX10R Esc with 4.5T Speed Passion MMM motor and my ratio is around 9. Usually driving in carpet low traction & mid technical track.
Can anyone advise me esc setting accourding to my car & track conditions ?!?
Thank you....
ringa is offline   Reply With Quote
Old 08-28-2012, 01:07 PM   #1010
ekim628's Avatar
PWM for throttle and brake- 16,000 hz
Drag brake- 8%
Boost turned off
Throttle punch- 90%
Eric K.
Old 08-29-2012, 08:13 AM   #1011
Thanks for your help & info ekim628.
Also, do you suggest me to upgrade esc to A55 ?!?
Thanks again
Old 08-31-2012, 05:35 PM   #1012
theatriks's Avatar
How hard is it to change the software on the vtx10....im trying and im having a heck of a time....im going to the website and downloading a file .....then i run it ...it asks me if i have the right speed control i continued.......then it says import and i cant find the file anywhere...any help would be appreciated thanks.
theatriks is offline   Reply With Quote
Old 08-31-2012, 06:15 PM   #1013
I've been interested in running a Viper ever since the first post about them here on RC Tech. Then having to wait a bit longer for the VTX1 to run in 1 cell 12th scale...so I ended up not getting one until recently. Ran my first race with a VTX1 in 1/12th scale last weekend and I gotta say I am impressed. The throttle response is very smooth, using the programmer is easy, and the built in booster worked very well even with my Spektrum radio system. My only complaint is the weight. The all metal case is really nice but the heat sink case really isn't all that necessary in 17.5 or 13.5 1/12th racing. Any plans for maybe an optional lighter case for 1/12th scale?
Old 08-31-2012, 08:28 PM   #1014
Trader Rating: 16 (100%+)
It will be in your documents folder or in my downloads. Search for it in windows search. Move it to my documents then it will be easier to find from the V link software. A lot of times windows will place the file somewhere odd unless you direct it to documents. If you still have trouble let me know.
Steve Downs
Team Kyosho, AKA Tires, COWRC, BOOMrc, Triton RC Engines, FTM Grip, Boca Bearings
steve downs is offline   Reply With Quote
Old 08-31-2012, 08:37 PM   #1015
theatriks's Avatar
Thats exactly what i did i took the downloaded file moved it to documents and from windows when i check my documents the file is there but when i go to import the file is not in documents...idk very frustrating
Old 08-31-2012, 09:41 PM   #1016
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
theatriks - is your esc connected with the PC and turned on (in "ProGauge" mode) when this happens? If the esc is not on the VLink doesn't always respond.
And it will ask to verify the correct unit is attached because the updated software is embedded in the program. So there is a different VLink for the 10, 10R and VTX1.
PM me is your still having issues, every computer is a little different, but I will try and walk you through it.
ringa - try a55 --your gonna like it!! Only if you want to go faster and run cooler.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 08-31-2012, 10:26 PM   #1017
Yeah what nikos said! Lol. He is the man I call when I have a question! He will get you through.
Steve Downs
Old 09-01-2012, 07:34 AM   #1018
theatriks's Avatar
holy smokes viper why do you make it so difficult to update software on your speedos!!!!.....i have everything hooked up and on everything! i got the speedo hooked up to the computer i got the sppedo on and i got the pro gauge hooked up to the speedo and still nothing!!!oh well i guess im stuck using the old software
Old 09-01-2012, 10:32 AM   #1019
macavant's Avatar
Trader Rating: 64 (100%+)
The progauge is not required to upgrade the firmware on the ESC. Make sure your ESC is in "programming mode" (as if connecting to the pro gauge) to get the ESC to communicate with your PC. Also - make sure Windows sees the ESC. I have updated all 3 of my ESCs to A55 just fine (VTX1, 10 and R). I'm running OS X, on VMware on a Windows 8 VM and the Viper program woks pretty good with this setup.
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 09-03-2012, 05:28 PM   #1020
I just got mine about a week ago...does it have the latest software on it? How do I tell what version it is? I have another on the way for my WGT car
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
