Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-23-2012, 04:47 PM   #976
rcnickv's Avatar
Default 1s usage for vtx-10
Is it possible to download vtx-1 software and use it in a vtx-10 to allow the vtx-10 to operate on 1s? I know it won't have the proper bec but I don't mind using a booster or rx pack. I can't remove the voltage cutoff or get it low enough to use 1s. I don't want to have to buy another esc if I decide to run 1/12th.
On another note I am extremely happy with the product while I have been running it in my touring car.
Thanks, Nick
rcnickv is offline   Reply With Quote
Old 07-23-2012, 08:21 PM   #977
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
V-link software has been released for anyone looking
http://www.viper-rc.com/pclink/updat..._VTX10_A55.zip
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 07-24-2012, 05:24 PM   #978
Please be aware i have had an issue going from firmware A19 to A55 the latest with the Vlink, Please make sure you have a back up copy of your current firmware incase you need to roll back, I Have made Viper aware
Pressure Washers and industrial cleaning equipment in the uk check out www.preciouswashers.co.uk
dazzler-pws is offline   Reply With Quote
Old 07-24-2012, 05:31 PM   #979
Me_MrTyson's Avatar
So is it better to upgrade to A30 first?
Old 07-24-2012, 05:39 PM   #980
I will be trying that tomorrow and will see if the problem stays, Just make sure you have a copy of your working firmware incase you suffer problems.
Old 07-24-2012, 10:34 PM   #981
macavant's Avatar
Trader Rating: 64 (100%+)
I had to upload the A55 firmware 3 times. The first 2 times - it seemed to have issues (red LED on, no arming - nothing else). The 3rd attempt, upon completion the message about radio calibration showed and then the ESC armed. My 2nd VTX10 with the A30 loaded w/o issues the first attempt. I'm holding off on loading the A55 on my VTX1...
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 07-25-2012, 10:21 AM   #982
Ive got a question. Im running the vtx10r w/ a 5.5 vst motor. im geared at 90t on the spur and 16t on the pinion gear. I use this on my hpi sprint 2 that i use for drifting. the problem that im having is that it wants to stop running. I have the motor and esc set to cut off at 160 degrees. what should i do to get it to run a lil cooler
twonb1 is offline   Reply With Quote
Old 07-25-2012, 01:53 PM   #983
What's new in A55?
-Mike
Old 07-25-2012, 02:11 PM   #984
when are the new motors coming out??
starrx is offline   Reply With Quote
Old 07-25-2012, 02:32 PM   #985
Originally Posted by grippgoat View Post
What's new in A55?
-Mike
More buttons to press, Vlink is very easy to use and understand on the computer.
I assume A55 is to make the speedo line up with the Vlink
Old 07-25-2012, 05:03 PM   #986
Me_MrTyson's Avatar
From the website what A55 has to offer
•Improved radio calibration process.
•Improved boost performance.
•Improved brake performance.
•V-Link Software for firmware updating and profile management,and ESC settings.
•Good for both on and off road applications
Old 07-26-2012, 05:02 PM   #987
b_recliner's Avatar
Trader Rating: 22 (100%+)
21.5 viper motor for sale cheap in this thread. thanks
http://www.rctech.net/forum/r-c-item...st-21-5-a.html
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 07-26-2012, 09:05 PM   #988
silvalis's Avatar
Trader Rating: 29 (100%+)
I updated all of my vipers to a55 earlier this week. One of them (VTX10) carked it shortly after, not sure what happened though. Another one (10R) has booted up incorrectly once (single red light), but worked fine afterwards.
I'll be seeing how my VTX1 in 12th and 10R in tc goes tomorrow with A55. Radio calibration and boost seemed about the same for me in offroad. Brakes seemed a little bit stronger. I also noticed that default brake freq. is now 2500Hz? I thought default used to be 3200 or something?
Biggest gripe for me right now (mentioned in offroad viper thread) is after modifying a profile in VLink, it isn't set as the operating profile. Have to switch that via the button or via progauge.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 07-27-2012, 06:19 AM   #989
Ciao Silvas,
posted this morning my impression on a55 on viper's forum, you are right new firmware improved the brake.
Viper's people explained both in their forum and facebook that vlink can only edit the profile, for chenge it in the esc you must use the progauge or the button as previous.
Two complains, first no data logger option available, non chance to print out esc set up
Ciao
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 08-01-2012, 06:18 PM   #990
nikos2002's Avatar
Send a message via AIM to nikos2002
Ciao, Max - thanks for the answer. That is correct, the VLink was not intended as a tool to change profiles, just the features within it.
Will it evolve -- how knows -- lots of cool ideas under consideration.
Curious to those who had the issues with it not "taking" the first time. Did you ever have update issues with the old program? Like you had to do it multiple times?
For those going to update the VTX1 - remember, its a separate VLink download, because the software differs for the 1s application.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
