Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-26-2012, 11:04 PM   #961
Originally Posted by MC112b View Post
Interested in maybe a VTX1 for a 21.5 blinker 1/12th scale class we have. The last few pages of thread has had mixed sort of results. How are these currently running 1s? Receiver packs? I would like to run without. Also, if I buy the esc with prg box, can I update software, or do I need another cable to connect to PC?
I got a VTX1 for my 1/12 scale NIB when I sold another car. It came with A30 on it. I wired it up with a 13.5, switched to profile 5, and after working through some confusion on my part with the radio calibration, it worked flawlessly. No booster, no glitches. I've had a VTX10 in my TC for quite a while, and it's also going strong. I'm quite satisfied with them, especially the pro gauge.
-Mike
Old 04-27-2012, 09:10 AM   #962
smyka's Avatar
Send a message via AIM to smyka
i have had no issues with any of my speedos and i have had two for more then 2 years now
as for 21.5 1/12 do you guys run boost or blinky ? i have not played with 21.5 at all but you can try this setting and see what it does with it
Profile a30
Brake strenght. 100
Brake frequency. 9600
Brake curve. Lin.
Dynamic brake
Trigger rpm 9500
Max brake. 2 percent
Dynamic curve. Lin.
Drag brake. 25 percent
Throttle frequency. 4000
Th punch. 100
Th. Curve Lin.
Motor power
Acc boost.
Start 3500
Finish. 17000
Max advance tim. 25
Top speed
Slew rate. 10/0.10 sec
Max advance tim. 20
Delay. 0.10
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 04-27-2012, 02:45 PM   #963
Trader Rating: 60 (100%+)
21.5 1/12 came about because 1/12 had basically died in our area. A few of us started running a 21.5 blinker class. The reduced speeds had us all racing very close. That temped several VTA racers to step up and buy 1/12 cars. We ended the season with a solid 9 cars. We hope to add a few more this fall when we start carpet racing again. The class has been great. No BS, no ego problems, just the right speed, awesome tire wear, and just a lot of laughs. It's what a novice/stock class should be.
So, I am fishing around looking at esc alternatives. The no booster/no receiver pack of the VX1 is tempting. It appears the blinky software is ROAR approved.
Would I need an additional cable/adapter for software updating?
MC112b is offline   Reply With Quote
Old 04-28-2012, 12:10 AM   #964
pcar951's Avatar
Trader Rating: 19 (100%+)
You will need the PC Link cable, sofware can be downloaded.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-11-2012, 03:13 AM   #965
how much the VTX1 weigh? I run 10.5 boosted WGT and I am looking to replace my tekin rs pro. The VTX1 looks like a solid unit but I am not sure about support for it in the UK.
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 05-11-2012, 06:39 AM   #966
Trader Rating: 16 (100%+)
I'll see if I can weigh mine today. I believe it may be only slightly heavier than the rs pro due to the machined case. I never had any weight problems in 1/12 or wgt running ae cars.
Steve Downs
Team Kyosho, AKA Tires, COWRC, BOOMrc, Triton RC Engines, FTM Grip, Boca Bearings
steve downs is offline   Reply With Quote
Old 05-11-2012, 11:28 AM   #967
RAL
RAL's Avatar
Chris,
We can support you from across the pond.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 05-23-2012, 12:13 PM   #968
ekim628's Avatar
Dear Loyal Viper Customers,
Viper will be attending the Reedy Race of Champions from May 23 to May 27. If your in the area please stop by see all the new products Viper RC will be releasing this year. All RMA's that come in or after May 24 will be taken care of the following Tuesday, May 29 due to Memorial Day Observation. We are sorry for any inconvenince this may cause you. We will take care of all RMA's as soon as we get back from the event. Thank You
Viper Service Center
Eric Kim
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 06-01-2012, 09:54 PM   #969
4wheeldrive's Avatar
Trader Rating: 22 (100%+)
Default I need some help
I need a good setup to start with for a 13.5 boosted setup. I will be running a SpeedPassion v3 13.5 with the VTX10 on an Xray 2011. The track is pretty big, big enough to run 1/8 scale so I would guess that the straight is about 120 feet. Any setup help would be appreciated.
4wheeldrive is offline   Reply With Quote
Old 06-01-2012, 10:19 PM   #970
pcar951's Avatar
Try this setup: http://www.viper-rc.com/forums/index...91.0;attach=63
It was indoor carpet with about 100ft straight, you'll probably have to adjust your FDR down some but, it should be a good start.
Jim Chapman
Old 06-08-2012, 07:35 PM   #971
Originally Posted by ekim628 View Post
I will definitely look into getting it approved. We never had this come up in VTA. I will look into it this week and let you know what steps we will take. Thanks for the heads up
Eric Kim
Any news on this? I would like to Beale to run a viper esc since all the others have issues.
MikeFrazer is offline   Reply With Quote
Old 06-12-2012, 08:57 AM   #972
Hi has anyone got a ball park roll out for the following ---
VST 10.5 single cell 1/12 on road boosted and blinky.
VST 8.5 two cell GT10 on road boosted and blinky.
Thanks for any help.
blackbird is offline   Reply With Quote
Old 06-12-2012, 03:08 PM   #973
Default Calibration issue: no brakes
Hello,
I installed a new vtx 17.5 system yesterday, but can't get the radio calibration correct. Forward works fine, but I have zero brakes. Was hoping someone could give me a clue. Here's what I did so far:
1. Turned on radio, neutraled all trims, and set throttle endpoints to 100. (radio is an old Futaba FM 3PDF)
2. Held down the red button on the ESC for about 3 seconds until the beeping musical tone indicated I was in calibration mode.
3. When the F and N LEDs lit, I held full throttle while I pushed the red button once for about a second and then let go. A tone sounded and then the N and R LED's lit.
4. I then held full reverse on the transmitter while I pushed the red button for a second again and then let go. After a slight delay, the ESC beeped its musical tone and entered Race mode.
However, I have no Brakes. Forward throttle seems fine (very fast and the F LED lights up). But there is no brake whatsoever nor does the R LED ever light up when I brake on the transmitter.
I've tried to set my endpoints to 120 F and 120 R and repeated the process but same result.
I've also tried different profiles as well but the same result.
The sensor cable seems attached correctly as forward power is smooth and very fast.
Also, in case it matters, firmware is A30.
Anyone have any ideas?
Thanks in advance.
Paul
paul18t is offline   Reply With Quote
Old 07-01-2012, 12:01 AM   #974
silvalis's Avatar
Trader Rating: 29 (100%+)
Got an X12 with a VTX1/Ion3 13.5. gearing 76/38 rollout about 73. Currently profile7 defaults.
Looking for a bit more mid throttle punch. Small track, so only touch full throttle once per lap, top speed is not an issue as I'd really only touch it for a fraction of a second then start slowing.
Should I
(a) put a bit more accel timing in
(b) change the start/end accel rpms
(c) change the rollout? I'm a bit clueless here - I see people using 60->85...
Also brakes seemed a bit weak, but easily workable. Not sure if this is due to a rwd pan (my first one)?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 07-01-2012, 07:52 AM   #975
Considering a vtx1 for WGT, because of its 1s capability. I would like to know if in the summer I could put it in a 4wd. Durango buggy with an 8.5 without any issues?
Beau
THE GOOCH is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
