Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-30-2012, 09:20 PM   #946
is there a spot on the vtx1 for a fan? like can i use the vtx10 fan on it? I have a vtx1 ordered but I can find a picture if i can hook up a fan as well. I want to use it in a 2 hr endurance race ..... might not hurt.
hellssephiroth is offline   Reply With Quote
Old 03-30-2012, 11:57 PM   #947
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
yes the cases are similar,
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 04-03-2012, 10:00 PM   #948
sangyi41's Avatar
Trader Rating: 16 (94%+)
Any good 10.5T Boost setup pairing with THunderpower Z3R motor?
VTX10 WIth A30 firmware.i cannot find better aceleration.
FDR around 6.3-6.6
Tough Racing Belt For MALAYSIA.TEAM POWER RC PRODUCT MALAYSIA Sale And Support.
FACEBOOK ONLINE RC STORE>>http://www.facebook.com/#!/groups/227796347309837/
Call/Sms/Whatsaps +60175007932 Location(Taiping,Perak)
sangyi41 is offline   Reply With Quote
Old 04-04-2012, 03:34 AM   #949
Hey sangyi41, i would say something like:
Acc Boost
St. RPM: 6000 - 7000
F. RPM: 15K - 17K
Max. Timing: 40 - 50
Top End
Slew rate: 20
Max. timing: 26
Delay: .4
All this assuming you have the standard timing on endbell and 4k on Th. Frequency.
Hope this helps.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 04-05-2012, 08:33 AM   #950
mkiiina's Avatar
Trader Rating: 69 (100%+)
Just wanted to post up about the Viper 25.5 motor I am using in my club vta class. It's awesome! Lots of torque and even with stock timing it screams down the front straight. Any word on getting the motor ROAR certified?
Looking forward to moving some of my other motors and esc's to Viper in the future!
mkiiina is offline   Reply With Quote
Old 04-05-2012, 12:51 PM   #951
Trader Rating: 42 (100%+)
If the viper 25.5 would get added to the list of VTA motors that would be awsome!!! I would be able to get back into VTA again.. as it sits our track only allows Novak Motor and Speed controls... so it has kinda closed the door to some of us that really enjoyed that class..
Team Radiopost-SMC Racing-R1wurks-Savox-AKA
XB2ce
BIGTRUX is offline   Reply With Quote
Old 04-08-2012, 09:55 PM   #952
ekim628's Avatar
I will definitely look into getting it approved. We never had this come up in VTA. I will look into it this week and let you know what steps we will take. Thanks for the heads up
Eric Kim
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 04-13-2012, 05:37 AM   #953
narcotiks's Avatar
can someone please explain in detail how the boost works with A30?
i know it is based on trigger position, but if you hit full throttle ANYWHERE on the track, will the speedy automatically apply top speed timing even if the motor hasn't reached the finish rpm or spooled up fully?
Say if I've gone around the apex of the corner and on the exit, i accidentally dab the throttle all the way, will it do what i said above?
And on the A30 manual it says that you should not exceed 60 degrees acc. timing and top speed timing. So can you go up to 60 regardless of end bell timing? and i've been given a setup that goes well beyond 60 degrees for acc and top speed timing together, can this be done or is it over timing the motor?
thanks.
narcotiks is offline   Reply With Quote
Old 04-19-2012, 12:35 PM   #954
ekim628's Avatar
The trigger rpm is actually influenced both by the trigger position and the rpm of the motor. This gives it the smoothness and accuracy to perform any advanced timing or boost. Thats the beauty of sensored brushlesss motors.
As for the total timing, you must not exceed 60 on the esc but you can go beyond 60 with the physical endbell (not recommended and produce heat)
To be safe you should stay within 60 degrees total. Not many situations demand any higher than that.
Hope that helps
thanks.
Eric K.
Old 04-19-2012, 08:36 PM   #955
Trader Rating: 72 (100%+)
I'm intrigued by the VTX10's motor over temperature protection feature. I'm running a motor with an onboard temperature sensor (i.e. Novak Ballistic). How can one tell when the ESC's motor temperature protection activates? In other words, if the ESC detects a motor-over-temp, what happens?
waswadener is offline   Reply With Quote
Old 04-19-2012, 08:53 PM   #956
Magnet Top's Avatar
Smoke pours out of the motor !
Magnet Top is offline   Reply With Quote
Old 04-20-2012, 04:32 AM   #957
It will shut down the motor and some lights flash but atm i don't remember exactly wich will.
Team AME/ORCA
Old 04-21-2012, 02:55 PM   #958
OK and thank you. Portugal? Nice! Spent some days in Porto a number of years ago. Splendid city.
Old 04-26-2012, 10:52 AM   #959
smyka's Avatar
Send a message via AIM to smyka
Hey guys for anyone running sedan or 1/12 with viper stuff i have some pretty good setups for open timming and blinky mode right now for a30 softwear i have other stuff to but it will have to wait till new softwear is out
mark smyka
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 04-26-2012, 03:25 PM   #960
Trader Rating: 60 (100%+)
mark smyka
Interested in maybe a VTX1 for a 21.5 blinker 1/12th scale class we have. The last few pages of thread has had mixed sort of results. How are these currently running 1s? Receiver packs? I would like to run without. Also, if I buy the esc with prg box, can I update software, or do I need another cable to connect to PC?
MC112b is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
