Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-01-2012, 08:13 PM   #916
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ekim628 View Post
Sorry about the hassel. I will make sure to put some notes on there somewhere to make it easier. We are coming out with a computer software but its taking longer than expected and wanted to avoid using that firmware app since its confusing for most users. I will make a note, thanks!!
It was a frustrating night after a frustrating day. Once I got it all figured out, the app is very simple to use, I thought. I also like the progauge, it makes tuning the esc very easy and does not req. a laptop at the track. I hope you dont change this, in my opinion, it is one of the selling points of your system.
I do like the esc, dont know if the smart brake made a big diff., but the car did seem easier to drive, and corner entry setup was more consistent. Will see if race lap times improve on fri. night.
SLOWINSLOWOUT is online now   Reply With Quote
Old 03-11-2012, 10:17 PM   #917
Scottmisfits's Avatar
Problem here guys. Very weird. It has quite a few of us stumped.
VTX1 ESC in a 12r5.2. I will lose power, only to the motor, at different parts on the track. I still have steering, the ESC doesn't shut off, I just lose all power to the motor.
So far I have tried 2 ESC's, 2 sensor wires, 3 motors, 2 radio's with a total of 4 different receivers, 2 batteries, and two different servo's. This is for 17.5 boosted class but I have also tried running in blinky mode and it does the same thing. I have turned the motor timing all the way and all the way down. Still no change.
Now comes the weird part. With a Tekin RS and a TQ booster, the car works. I'd rather run the Viper if I can but there is something that is just not working.
Anyone have any thoughts without just putting the Tekin system back in?
Scottmisfits is offline   Reply With Quote
Old 03-11-2012, 10:21 PM   #918
narcotiks's Avatar
It sounds like your over heating the motor and the esc is cutting it off to prevent cooking it. There is something wrong either your gearing or boost settings. Ask one of the viper guys to help you with settings to get good speed and not over heating.
Also helps to put a big heat sink and fan on the motor
narcotiks is offline   Reply With Quote
Old 03-11-2012, 10:25 PM   #919
This happens on the first lap. The motor isn't getting any hotter than a couple of degree's above room temp, if that. Like I said, it does it in blinky mode as well.
Old 03-11-2012, 10:44 PM   #920
narcotiks's Avatar
What's your motor temp cut off set at? And check your sensor cable it might be damadged or not plugged in properly
Old 03-11-2012, 10:45 PM   #921
narcotiks's Avatar
And what firmware are you on ?
Old 03-11-2012, 10:51 PM   #922
I have hit motor cut off with other cars. This is not that. But my ct off is set at 180*. Sensor wire is good. I have tried a couple of different ones and checked them both on my motor checker.
Old 03-11-2012, 11:00 PM   #923
narcotiks's Avatar
I have no idea what could be causing this apart from a faulty Esc or motor?
Old 03-11-2012, 11:12 PM   #924
All three motors and at least the one ESC that doesn't work for me, work in other vehicles.
It's very frustrating for me.
Old 03-12-2012, 12:35 AM   #925
narcotiks's Avatar
Must be extremely frustrating haha!
Could be to do with the transmitter ? Which one are you running ?
I use a vtx 10 with a spektrum dx3r and have no issues
Old 03-12-2012, 06:08 AM   #926
Originally Posted by blackbird View Post
Mike, I had the same problem when setting up my VTX1 with A30 software, esc would shut down and rearm. Traced the problem to the neutral setting of my transmitter here is what I had to do to overcome this problem (my radio is futaba 3vcs with spektrum 2.4ghz module) on transmitter set brake/throttle mode to 50/50( instead of70/30) and put throttle and brake transmitter end points to 120% (instead of 100%) then calibrate with esc and shutdown problem is cured.
Hope its of some help to you as have now run esc and am impressed with it.
Had a similar fault with my VTX1 this is what I had to do with my radio to stop fault.
blackbird is offline   Reply With Quote
Old 03-12-2012, 07:26 AM   #927
silvalis's Avatar
Trader Rating: 29 (100%+)
Has anyone with a progauge played with the PPM monitor? I'm curious to what other radio systems frequencies are.
For example
Eurus FHSS/KR411FH = 177Hz (Adv) 177Hz (HiSpd) 60Hz (Norm)
DX3S/SR300 = 90Hz (11ms) 60Hz (16.5ms)
3PKS/R203GF = 77Hz
silvalis is offline   Reply With Quote
Old 03-12-2012, 07:44 AM   #928
narcotiks's Avatar
I need help with setup and gearing using a vtx 10 and vst 21.5 motor
Running in the 21.5 boosted class on a pretty high grip track with I think roughly 35 m straight
Thanks guys
-Yanni
Old 03-12-2012, 08:40 AM   #929
But the ESC doesn't shut off, it just drops power to the motor. I would bet that if I put a small receiver pack on it, just to give it some extra juice, and full voltage, it ill work fine. I would bet my car, after doing some research, that it's the internal BEC that can't keep up.
Old 03-12-2012, 01:40 PM   #930
How much output does the VTX1 Booster/BEC have? Adjustable voltage between 4.5-5.5 volts, but hw about the amp rating on it? If I put an external receiver pack on it, I bet the issues go away. Any thoughts on this Erik?
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
