Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-02-2012, 01:15 PM   #871
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by pcar951 View Post
7.2 to 7.7 FDR, for best punch on a small technical carpet track (TC 13.5 boosted).
looking for FDR to 13.5 blinky
gonzo416 is offline   Reply With Quote
Old 02-02-2012, 01:40 PM   #872
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Try 3.8-4.0 depending on track size. And turn the motor timing up. Adjust gearing for punch/top speed and motor temp. 150-160deg F is ok.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-02-2012, 02:13 PM   #873
gonzo416's Avatar
Track is 70 x 40. Should I use the regular rotor or the 12.3?
Old 02-03-2012, 09:32 PM   #874
Planning on getting the VTX1 esc and would like to know how is it performing so far for those who have it, good and bad.
RoyU is offline   Reply With Quote
Old 02-03-2012, 10:33 PM   #875
rc pete's Avatar
Been running one in my Stock TC (17.5 blinky) and 1/12 Stock and Super Stock over the last 3 weeks. It's been excellent in both. At the Western Canadian Indoor Champs Series last weekend I TQ'd & won the TC stock class with it, and TQ'd & finished 2nd in the 1/12 Super stock (was winning when I chunked a tire... foam.. what are you going to do, right?). It ships with A30 firmware which works great with 2S lipo, but you need to run the A25 software for 1S.
Pete
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 02-03-2012, 10:35 PM   #876
rc lover's Avatar
Trader Rating: 18 (95%+)
Send a message via Yahoo to rc lover
Smile brushless
Is this setup for 1/10 scale on road stock and mod.
Abdul (AKA) THE Heat ALI
rc lover is offline   Reply With Quote
Old 02-04-2012, 09:18 AM   #877
Hey Pete,
You wouldn't happen to have a recommendation for a starting point for 12th Stock (boosted 17.5T) would you. I picked up a VTX1 last night and I'd like to run it at the KARZ race tonight.
Cheers,
Mike
Pete
Mike
Hyper_Mike is offline   Reply With Quote
Old 02-04-2012, 04:29 PM   #878
gonzo416's Avatar
Thanks. I was at 4.15 with 1 line less than full timing on the can. Highest temp has been 150deg. I'm going to go up a tooth and see if it will help.
Old 02-07-2012, 12:38 AM   #879
ekim628's Avatar
Pete
The VTX1 A30 software that comes pre-installed works with both 1S and 2S. Did the A30 not work for you? Please Pete know so I can help you.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 02-07-2012, 02:19 PM   #880
Default Setup for 1 cell modified
I have frequently looked at Viper´s homepage for some setup´s for 1 cell modifeid. But it still said comming soon. Does anyone have a good setup for the VTX1 1 cell modified 1/12 class.
Running a 3.0 speedpassion. I have run the tekin reg, but want to get rid of the booster or reciever pack to get the weight down and keep the weiring simpler.
I have no place to practice and have a race cooming up this weekend.
Hope someone have a setup they would share, it would save me lots of time under the practice round.
In advance thanks.
speikey is offline   Reply With Quote
Old 02-07-2012, 03:59 PM   #881
I'm not Pete but I race with him and raced on Saturday night with my brand new VTX1 w/ A30 software. Part way through the 2nd and 3rd qualies my car would just "freak out" for a split second. It would suddenly stop dead and coast for a second and then start working again. Pete indicated that when he first used is VTX1 w/ A30 software it did the same thing to him. Once he switched to A25 the problem went away. The other issue that I had was that I had NO brakes even with braking set to maximum. I'd hit full brakes and the car would coast for 6-8 feet before stopping. I'm not sure what to make of it as I'm brand new to Viper products but I suspect I'll load A25 into mine based on mine and Pete's experience.
Cheers,
Mike
Mike
Old 02-07-2012, 06:40 PM   #882
Dog Bone's Avatar
One other issue you may run into is that trying to use the programmer with A30 on the VTX1 may not work properly - I had a heck of a time getting the ESC into program mode with A30.
Once I installed A25, no issues.
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 02-07-2012, 08:19 PM   #883
dag32's Avatar
Trader Rating: 109 (100%+)
I just purchased a VTX1 and have yet to install it into my 1/12, I hope I don't have these issues because it might be my first and last Viper product.
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 02-08-2012, 08:49 AM   #884
rc pete's Avatar
For me that turned out to be user error.
You need to get the ESC into program mode first and then plug in the ProGuage (as per the instructions).
I've got one VTX1 on A25 in my 1/12 and one on A30 in my TC, and haven't had this issue since I started doing it in the right sequence.
Old 02-08-2012, 08:53 AM   #885
Cheers,
Mike
Mike, I had the same problem when setting up my VTX1 with A30 software, esc would shut down and rearm. Traced the problem to the neutral setting of my transmitter here is what I had to do to overcome this problem (my radio is futaba 3vcs with spektrum 2.4ghz module) on transmitter set brake/throttle mode to 50/50( instead of70/30) and put throttle and brake transmitter end points to 120% (instead of 100%) then calibrate with esc and shutdown problem is cured.
Hope its of some help to you as have now run esc and am impressed with it.
blackbird is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
