Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 01-10-2012, 02:54 AM   #841
Ciao to all,
last sunday raced for the first time vtx10r with a30 firmware, with hobbywing 10,5 motor, very very impressive performance, fast car but with a super smooth accelleration, still to find the sweet spot with the brake next week i'll do some test in order to find the good brake setup.
Max
mtaddei is offline   Reply With Quote
Old 01-10-2012, 05:04 PM   #842
narcotiks's Avatar
Hi guys,
On my tc with vtx10 and vst 13.5 motor (using profile 7) the motor has no definitive kick into boost , and at full throttle it kinda pauses and starts rapidly , seems like its struggling to put out the power that the Esc is giving..
I have had motor issues before and I was told that the motor will die eventually if you have burnt it...
So is the motor fried? And if it is the Esc, how would I tell if it is?
narcotiks is offline   Reply With Quote
Old 01-10-2012, 05:08 PM   #843
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Narcotics
are you running 0 Degree timing on the motor ? or any ?
If so set it back to 0 Degrees and try again.
My motors didn't like the boost with mechanical timing on the motor.
Also Gearing make sure you on a comfortable gearing, and not geared to the moon.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 01-10-2012, 08:53 PM   #844
rc pete's Avatar
Originally Posted by narcotiks View Post
Hi guys,
Profile 7 should get you pretty close. I run 13.5 boosted in my TC on a tight carpet track, with great success. My setup sheet is on the viper-rc.com site: http://viper-rc.com/forums/index.php...4.0;attach=102 (BTW, you have to register to see attachments)
If you run on a large track, you can start there but gear up a couple of teeth and stretch out the Finish acceleration to get better mid-range (check temp after 2 minutes).
Timing on the motor could be an issue. Start around the neutral mark, and if you need more bottom end start advancing it and watch your temp.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-10-2012, 09:18 PM   #845
CaLaBeR's Avatar
Does anyone have a good setup for VTX10R with Viper 17.5? It is in a S 411 TC on a tight carpet track. Thanks
Pro-Line Racing ~ The Nitro Shop
CaLaBeR is offline   Reply With Quote
Old 01-11-2012, 12:57 AM   #846
narcotiks's Avatar
Thanks for your help dude
But my problem is that the motor was
Working fine and VERY fast until I had a very hot run on a very hot day and then damaged the rotor (scratches) and the sensor board (fixed )
Which was the last time I went for a practice . When I arrived at the track and gave my car a test on the car stand , I noticed the speed was substantially lower than usual. And by the end of my 2 hour practice , it had the problems I explained above . So I had it working perfectly and now it isnt. Do
You think it is the motor ? Should I get a new one?
And if I do get a new motor , can it be any brand?
Old 01-15-2012, 04:41 PM   #847
Trader Rating: 13 (93%+)
is the VST 17.5 black edition a 540 motor and is it avalible?
Scott.K is offline   Reply With Quote
Old 01-15-2012, 05:13 PM   #848
gonzo416's Avatar
Trader Rating: 39 (98%+)
Anyone have a good FDR for a 13.5 blinky?
gonzo416 is offline   Reply With Quote
Old 01-15-2012, 05:15 PM   #849
gonzo416's Avatar
Rubber Tire Sedan Carpet, Oh! and timing
Old 01-16-2012, 11:44 PM   #850
narcotiks's Avatar
Can anyone give me some help with my question above ?
Old 01-17-2012, 12:17 AM   #851
pcar951's Avatar
Trader Rating: 19 (100%+)
Hi guys,
How hot did the motor get?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-17-2012, 12:21 AM   #852
pcar951's Avatar
7.2 to 7.7 FDR, for best punch on a small technical carpet track (TC 13.5 boosted).
Jim Chapman
Old 01-17-2012, 04:31 AM   #853
narcotiks's Avatar
Hot to the point that I couldent keep my finger on it for longer than like a second, not even
Old 01-17-2012, 09:25 AM   #854
4wheeldrive's Avatar
Trader Rating: 22 (100%+)
I used the setting from rc Pete that he had listed and it worked just fine for me. I have an Xray T3 2011 with a Speedpassion v3 13.5 motor and was geared at 7.47 my motor never temped beyond 160. I felt that the car was boosting a little to late down the straight and some of the short shoots. I have to figure out on this track how to get the boost to come in a little sooner. I felt that once the boost kicked in I was at the point where you would let off to approach the entry to the turn, so I would overshoot and push out.
Don't get me wrong, this setting is spot on to start with so your track may differ.
On a bigger track this might be just the setup but I'm new to the viper boost setting as I have been running non boost with my VTX10.
4wheeldrive is offline   Reply With Quote
Old 01-17-2012, 10:14 AM   #855
pcar951's Avatar
Are you running any physical timing on the can? What firmware version? Just trying to get some info to sort this out... Sounds like too much timing being applied in the midrange possibly.
Jim Chapman
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
