Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-16-2011, 01:22 PM   #796
Profile 2. Stock settings besides punch 80%. Gearing stock spur?11 pinion tight track. Battery 2s 5,000 reedy.
Lendel Smith
SikKustomz is offline   Reply With Quote
Old 12-17-2011, 05:29 AM   #797
please send mail to [email protected] because in my point of view could be more of a RMA thing.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 12-20-2011, 05:46 AM   #798
narcotiks's Avatar
The capacitor wire connected to the PCB on the vtx 10
The negative capacitor prong closest to the negative battery port and the the part of the PCB connecting to the negative battery port are touching , im not sure if this is my doing by trying to tin the ports or from the factory... ?????
narcotiks is offline   Reply With Quote
Old 12-20-2011, 07:46 AM   #799
Sorry, but i don't understand what you mean, could you post a photo plz.
Thanks in advance.
Team AME/ORCA
Old 12-20-2011, 08:25 AM   #800
Are you talking about this on the circle:
From factory.
Team AME/ORCA
Old 12-20-2011, 02:37 PM   #801
narcotiks's Avatar
From factory.
Yeah that right there haha thank god!
Is there a teqnique to soldering the wires to the esc cause I'm having some trouble ... Using lead free solder
Old 12-20-2011, 03:40 PM   #802
wingracer's Avatar
Trader Rating: 24 (100%+)
Ditch the lead free solder. Get some good 60/40 rosin core.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-20-2011, 04:03 PM   #803
I had trouble, too. I'm using 60/40. The Viper is REALLY good at conducting heat away from the solder terminals. I found using a higher wattage iron helped (was originally using 40w, I think the one I'm using now is like 50w?). Put it on max temp. Give it a good long time to get up to temp. And give it a good long time to recover between wires. Whenever I borrow a fellow racer's 60w induction iron at the track, it always goes much more smoothly. At some point I'll have to get something nicer.
-Mike
Old 12-20-2011, 04:36 PM   #804
narcotiks's Avatar
-Mike
How did you end up doing it? I'm finding it really difficult to do
I've got one of the really high end weller soldering stations and have currently got it on 425 degrees and it's beginning to heat up the terminals quicker to tin them.. I just tried To clean off all the lead free solder that I tinned on the terminals and I'm gonna use 60/40 but still it's tricky. How did everyone do theirs? Tin wires onto the terminals with a little extra solder fed in? Or tinned the ports and wires and extra solder ...???
Old 12-20-2011, 06:42 PM   #805
I didnīt have any problem, my guess is your solder is not so good, but a good 60/40 1mm solder should do the work, no need for long time heat in the posts. Just apply solder to the posts, the wire are pre solder applied use that end and should be more than enough and easy. Also soldering station is a must have nowadays.
Team AME/ORCA
Old 12-25-2011, 12:43 AM   #806
narcotiks's Avatar
how do you remove the circuit board part of the motor? and can the stator be removed so i can inspect it?
Old 12-25-2011, 10:39 AM   #807
There is video on youtube, check for viper. It's 3d animated but you can check it. On the phone right now, so not easy to post it. About the stator i don't advice to take it out.
Team AME/ORCA
Old 12-26-2011, 03:41 PM   #808
ekim628's Avatar
Here is the helpful 3D animation video
http://www.youtube.com/watch?v=_WUFn...2&feature=plcp
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 12-26-2011, 06:05 PM   #809
4wheeldrive's Avatar
Trader Rating: 22 (100%+)
I downloaded the newest viper update and the instructions say to open up the .rar file but the file for version A30 is a .vuf file. Am I missing something here? What do I do with the file now?
4wheeldrive is offline   Reply With Quote
Old 12-26-2011, 07:13 PM   #810
narcotiks's Avatar
managed to re solder the tiny black comonent, but i seeem to have lost the little spring that goes on the front end of the rotor. does this spring do anything imortant?
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
