Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-14-2011, 05:49 PM   #781
I have a vtx10r in a sc104x4. The motor is a 5.0L. Last week was the first run with it and the truck would shut off. Nothing was over 130 degrees. I tried diffrent battery and sinsior wire. Any help?
Lendel Smith
SikKustomz is offline   Reply With Quote
Old 12-15-2011, 03:41 AM   #782
Wich brand motor?
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 12-15-2011, 09:53 AM   #783
Viper 550 5.0L. The whole truck will shut off. Press the button turns on everything works fine. Almost seems to be a pattern will shut off after about 2 laps then after I can finsh the race?
Lendel Smith
Old 12-15-2011, 09:58 AM   #784
Trader Rating: 42 (100%+)
I would check your temp shut off settings and if that does nothing try to redo all your solder joints.. After that I would try trading out different components to narrow down the problem.
Team Radiopost-SMC Racing-R1wurks-Savox-AKA
XB2ce
BIGTRUX is offline   Reply With Quote
Old 12-15-2011, 10:04 AM   #785
Shut off temps are at 220. Nothing seen over 130. Tried diffrent motor still did it. When I run in practice mode never shut off?
Lendel Smith
Old 12-15-2011, 10:31 AM   #786
Have you tried to disable shut off temp cut for motor? That happen since new?
Team AME/ORCA
Old 12-15-2011, 10:35 AM   #787
Wait, even servo won't work?
Team AME/ORCA
Old 12-15-2011, 12:22 PM   #788
ghoppa's Avatar
Trader Rating: 54 (98%+)
how old is your VTX10R??
and what was the ambient temperature you were racing in?? was it hot??
I have had this problem with the 1st run of the VTX10R cutting off when I was running in really hot conditions. Happened this past summer indoor when ambient temps were around 85-90*...
if this is the case, I know the guys @ the main office in WA will take care of your problem...
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 12-15-2011, 02:41 PM   #789
Servo nothing truck powers off. Temps around 65-75 indoor racing. I have had sinsior wire problems do weird things. Vtx10r is around 2 months old. I have checked all the wires everything looks to be solder great. No cuts in any of the wires. On another note could the bec be to low? Will that cause the truck to shut completely off?
Lendel Smith
Old 12-16-2011, 03:52 AM   #790
If it powers off could be something else, i think BEC will only be a "problem" if set to high, gonna check what could cause the problem, will get back.
Team AME/ORCA
Old 12-16-2011, 07:24 AM   #791
csracing's Avatar
Trader Rating: 22 (100%+)
Installing a new VTX10 this afternoon. I did not buy the pro gauge since I run 17.5 blinky right now. I'm curious though if there are any plans to create an andriod app for tuning? Sorry if this has been covered, I only read the last 25 pages or so of this thread.
CSR
csracing is offline   Reply With Quote
Old 12-16-2011, 09:14 AM   #792
It is in the "to do" list:
Team AME/ORCA
Old 12-16-2011, 09:21 AM   #793
csracing's Avatar
Very cool. Any estimation on when it will be released?
Old 12-16-2011, 11:19 AM   #794
Thanks!
Lendel Smith
Old 12-16-2011, 11:34 AM   #795
Thanks!
Give just some more info:
- Gear Ratio used;
- Which profile did you run and what specific parameters did you change.
Team AME/ORCA
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
