Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-22-2011, 09:36 AM   #631
Ciao Jorge,
tnks for yr replay, however i got a very bad surprise, in order to flash the new firmware i must purchase the pclink , despite other brands that you cand do it using the programcard
Could you pls suggest me where to buy it???
The motor i can choose between Team Wave linear motor and Lipotech.
Ciao
Max
mtaddei is offline   Reply With Quote
Old 09-22-2011, 10:18 AM   #632
Originally Posted by mtaddei View Post
Ciao Jorge,
Ciao
Max
In europe your best shot is to try to contact Xfactory and see where they stock Viper products.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 09-22-2011, 01:32 PM   #633
Ciao Jorge,
pclink purchased from amain, in any case it will not arrive in time for next sunday, i'll try the set up suggested with a lower value, as maybe the straight it less the 50 mtrs
ciao
max
Old 09-22-2011, 02:03 PM   #634
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
who do we need to contact about carrying these ESC's at our hobbyshop?
ovalnator is offline   Reply With Quote
Old 09-22-2011, 03:33 PM   #635
Dealer inquiry - just fill that form.
Team AME/ORCA
Old 09-22-2011, 03:51 PM   #636
Ciao Jorge,
ciao
max
So try to do it like this:
Put some negative EXP on throttle, try to put the throttle back to 50% and fdr maybe 5.5 ~ 5, but pay serious attention on the motor temperature. A fan should always be a good add.
Team AME/ORCA
Old 09-22-2011, 10:38 PM   #637
macavant's Avatar
Trader Rating: 64 (100%+)
delete post
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 09-23-2011, 12:08 AM   #638
Ciao Jorge,
well noted, i'll revert you next monday with impression.
In the meantime could you pls advise the download link of the pclink software to be installed in the computer, as i didn't find it on viper www.
Tnks n best rgds
Max
Old 09-23-2011, 02:48 AM   #639
Send me your mail trough pm.
Team AME/ORCA
Old 09-24-2011, 02:19 PM   #640
1shnot's Avatar
Thinking about buying a Viper 17.5 to try... has anyone have any experience with duo series motors vs viper?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 09-24-2011, 11:22 PM   #641
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
the duo series of motors have more rpm than the viper 17.5 so if you are going to get the viper i highly suggest getting the 12.3mm rotor for it as well.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 10-01-2011, 08:59 PM   #642
4wheeldrive's Avatar
Trader Rating: 22 (100%+)
What does it mean when the lights F/R/S are blinking at the same time. While I was running several times after about 6min or so the car stopped and these lights were blinking.
Specs
Motor - Tekin 21.5
Motor timing - 20deg
motor temp - 100deg (never really went past that after 5-6 runs on carpet)
ESC Temp - 88deg max
Gearing - started with 4.17 and ended up with 3.80 and never went past 110deg in motor and esc.
I'm running version A19 (this is what shows when I connect the programmer)
4wheeldrive is offline   Reply With Quote
Old 10-01-2011, 09:29 PM   #643
Do you have the part # for the stock spec 12.3mm rotor? The one I found on Amainhobbies seems to be a mod rotor...
http://www.amainhobbies.com/product_...rque-VST-Rotor
JamesL_71 is offline   Reply With Quote
Old 10-02-2011, 09:59 AM   #644
im looking to buy this setup for my traxxas 4310 4tec.... i was wondering what turn motor should i get for the best speed and torque... im new to electrics sry lol.... what type of gearing are yall running also for top speed with torque for low end... thanks for the help you can pm me if any more information is needed
gsrcivic is offline   Reply With Quote
Old 10-02-2011, 12:06 PM   #645
Specs
Motor - Tekin 21.5
It's thermal cut. Check your Motor Temperature Cut and remenber that you read outside the can and that could mean more 20-30 inside the motor where the ESC reads.
Team AME/ORCA
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
