Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-18-2011, 10:08 PM   #616
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Does Weylin still work for Viper? I need to get some help with a VTX10R that is thermalling with a 4.5T in onroad 4wd touring.
Ooj is offline   Reply With Quote
Old 09-19-2011, 02:54 PM   #617
b_recliner's Avatar
Trader Rating: 22 (100%+)
Originally Posted by jeff jenkins View Post
the team is testing the newest version of the 1s speedo as we speak. so still in the testing stage. but its coming.
Thank you Jeff. I'm in the market for a 1/12 speedo for the upcoming carpet season. I have a VTX10R in my touring car and love it. I'm really holding on to hope that the twelver delivers as well.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 09-19-2011, 03:22 PM   #618
ok! i was racing on sat & i practice all day & got to the 3rd QUAILIFIER & my esc vtrax10 unprogramed its self...so i try to reprogram it & it wont...it do everything but the last part when all the lights flash.....i try this for about an hour...i calibrated my radio...epa @ 100 & i tryed 120....so am i missing something or do i need to send it back...im was running 17.5 blinky 4.0 fdr on profile 5.. duo 2 motor
starrx is offline   Reply With Quote
Old 09-19-2011, 03:22 PM   #619
b_recliner's Avatar
Can the vtx10 or vtx10r be run on 1s with a booster?
Old 09-19-2011, 04:52 PM   #620
ghoppa's Avatar
Trader Rating: 54 (98%+)
need more info in order to assist..
-need track info? (size of straight and type of infield)
-what are your current esc settings and motor timing??
i am sure we can help point you in the right direction...
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 09-19-2011, 09:28 PM   #621
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
are you using the pro-guage?? need to know a little more on what you are trying to do are you trying to re-calibrate or trying to just load settings and save them?
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 09-20-2011, 04:27 AM   #622
im just tryna to get it to work...i go through the steps of programing it & it wont do the last step....when all the lights cycle @ the end....im tryna to re-calibrate it....some how is un-calibrated it self
Old 09-20-2011, 04:50 AM   #623
Ooj
Hey Everyone,
This is actually my 2nd VTX10R. The first one I got just stopped working on its second lap and I had it RMA'ed. Viper sent me a brand new one because they were concerned that that ESC which came from the first production batch might have had some BEC issues. Anyways since I got the new ESC I've been running the settings recommended by Weylin and they are also very similar to my Speedpassion GT2.0. Track is low grip concrete, tight and main straight is 20m long.
Settings run were:
VTX10R
VST 4.5 motor with 45 degrees timing
Hotbodies TCX 4wd touring on rubber tires
Air temp 10 degrees celcius.
Profile 6
Stock mode (boost disabled)
FDR 8.08 and 8.5
Punch 60%
Brake PWM 3200
Throttle PWM Tried 4000, 5000, 8000, 12000, 16000
The motor is cool to the touch and it is only the ESC that is getting very hot. All of the combos listed have resulted in the ESC thermalling at 5 minutes. I have also had it shut down and play dead for a while.
Anyways I just wanted to get some help from Viper because it has been almost 2 months since I sent the email to Weylin.
Old 09-20-2011, 07:05 AM   #624
Hey Everyone,
Settings run were:
VTX10R
Profile 6
FDR 8.08 and 8.5
Punch 60%
Brake PWM 3200
Actually Weylin does not work as team manager no more in Viper.
I would try to get the timing in the can back to 30, this will give more punch and less speed, but at a 20 mts straight you will certainly be lacking him. My guess is to go for 8.7 FDR, also check your brakes and drag brake, on a tight track if your abusing on them maybe your overheating the motor.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 09-20-2011, 07:21 AM   #625
Ooj
Hi Jorge,
Thanks for the tips. I'll give it a try and report back.
Old 09-20-2011, 09:31 AM   #626
Hi Jorge,
Also a thin rotor would help, actually i found that the less the turns the thinner your rotor will have to be, i like more the feeling.
Team AME/ORCA
Old 09-20-2011, 04:18 PM   #627
ghoppa's Avatar
also,
Viper motors tend to like being geared up, so "yes" I also agree with Jorgesimes and immediate turn down the endbell timing to 30* which will increase punch and gear up 1-2 teeth on your pinion to gain on top end..
also, please keep in mind that as you increase the PWM on both the throttle and brake setting on your Pro Gauge this will also lead towards a higher operating temp on both the ESC and Motor.. Depending on your track layout/race conditions, you can always lower your brake power % settings ON YOUR ESC (not the EPA on your radio) to a lower number, try 80% to start off. This will definitely lower operating temps on your Viper gear.
lastly, give Profile #5 a try and decrease your brake power to 80% to start off and also disable the dynamic brake option. Check your motor/esc temps after running hard @ the 3, 5 & 7 min marks and go from there...
hope this helps keep us updated,
good luck!
Old 09-21-2011, 03:13 AM   #628
also,
good luck!
Jorge Like's This.
Team AME/ORCA
Old 09-22-2011, 06:32 AM   #629
Default 10.5 boosted class
Ciao guys,
next sunday after a very long time i'll test my vtx10r for the first time.
Could somebody help me with a starting setting?, the track is on asphalt
and the straight is abt 50 mtrs long.
Tnks for the help
Max
mtaddei is offline   Reply With Quote
Old 09-22-2011, 07:05 AM   #630
First of all, try to get the latest firmware, instructions on Viper Forum trough Viper Web. If you don't have the latest firmware i do not advice to use boost in such a long straight track.
My personal advice will be (new firmware):
Mode 7
Disable Dynamic Brake
0 neutral brake
Acc Boost
Start RPM: 4000 RPM
Finish RPM: 15000 ~ 16000 RPM
Max. Advance Timing: 30
Top Timing
Slew Rate: 10 ~ 15
Timing: 30
FDR: 6
Wich specific motor is? (brand)
Team AME/ORCA
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
