Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 05-31-2011, 06:43 AM   #481
Originally Posted by starrx View Post
can somebody tell me what is boost timer..1-10mins
& what trigger rpm's do
thanks
ANYBODY??
starrx is online now   Reply With Quote
Old 05-31-2011, 08:49 AM   #482
Originally Posted by one2three_us View Post
Just finished 2011 Reedy with 10R ESC with Team Power 17.5. ESC makes the motor more powerful than running with TEKIN ESC regardless how much heavier the 10R compare with my RS Pro. I was able to catch up with the faster guys with Novak and Tekin from the back of the grid. Unfortunately didn't get a chance to run with Viper motor (Defect with 1 bad screw ). Looking forward to try agin! . THANKS!
did you run profile-1, profile-5, or did you tweak some of the settings?
thank you.
gdcopbdcop is offline   Reply With Quote
Old 05-31-2011, 10:52 AM   #483
thank you.
Profile 5. Bone Stock. The sooner I put on the ESC, the motor feels totally different. I guess the MAX throttle punch have more power than MAX out in Tekin RS Pro
one2three_us is offline   Reply With Quote
Old 05-31-2011, 12:45 PM   #484
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
The Viper VTX10 esc was super smooth in 17.5 NT all weekend at the Reedy Race, standing tall without any issues. The efficiency really was amazing due to the quality of the internal components. Switching to the same FDR of a few other drivers using the same motor, I temped my motor after an early practice run to see in disbelief that the motor temp was only 103 deg. Needless to say I geared up two teeth. Quality you can feel.
Congrats to Viper's Eric Kim on winning his Open Mod Main and bringing home the hardware!
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 05-31-2011, 09:37 PM   #485
what motor did you use? where was the timing on the motor set, and what was your final fdr?
I use this speed-o in my touring car, and i am hoping to get a good set up for it?
thanks in advance.
Old 05-31-2011, 09:39 PM   #486
thanks in advance.
ooops! just saw the team powers motor.
thank you for the rest.
Old 06-01-2011, 12:14 AM   #487
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
What is Hole Shot Launch?
Ooj is offline   Reply With Quote
Old 06-01-2011, 12:25 AM   #488
thanks in advance.
hope u get a nice set up soon.
highhigh is offline   Reply With Quote
Old 06-01-2011, 01:14 AM   #489
FDR @ 3.88 with a 40mm fan. highest temp @ 161. I have no clue what hole shot is so I turned it off. The Motor timing was MAX OUT
Old 06-01-2011, 03:55 AM   #490
From my understanding is a kind of extra boost for main starting grid.
jorgesimes is offline   Reply With Quote
Old 06-01-2011, 04:02 AM   #491
thanks
Sorry, where do you see boost Timer?
Trigger RPM is a part of the dynamic drag brake and it sets the RPM from where the drag brake engages with your defined max brake strength.
Hope this helps.
Old 06-01-2011, 04:38 AM   #492
Ooj
Thanks Jorge.
I finally got everything up and running and wrote down the default values for the 8 pre loaded profiles.
Just need to work on a boosted 4.5T touring profile now!
Old 06-01-2011, 04:48 AM   #493
Nice add.
My personnal advice is that you don't use timing boost for now on large tracks. Tests are almost finished for a very good improved firmware on large tracks.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
Old 06-01-2011, 04:50 AM   #494
Ooj
Brilliant! Can't wait to see what any new firmware has to offer. Would also be good to get the USB PC link when it becomes available.
Old 06-01-2011, 05:00 AM   #495
It's allready available. Send an email at viper, they will help you for sure where to get it.
Team AME/ORCA
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
