Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 01-27-2011, 07:14 PM   #181
Originally Posted by arn671 View Post
I'm running the 17.5 Viper and compared to a Ballistic or DUO 1 and 3, they seem to like gearing that is at least 2 teeth taller (64p) the Duo's and Ballistic I had geared at 3.7-3.8 for a Med-High bite carpet track vs. 3.5-3.6 for the Viper non-boosted blinky mode, that was with a Tekin RS-pro, SXX SS and now the Viper speedo. The Speedo has the same size footprint as the SXX SS, and responds extremely we to changes-not to mention the ease of programming. Hope that helps
thanks! i will give it a try on sunday........i compared mine's to a novak ss..that has lot of torque & a duo 2 that had lots of rpm's
did you have the timing turned up on your viper motor??
& have you try 1 of the tuned rotors??....i have the 12.3 1 but didnt try it yet
starrx is offline   Reply With Quote
Old 01-27-2011, 07:51 PM   #182
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
the viper vst motors have more torque in them than your duo's and ballistics so yes they need a minimum of 2 teeth bigger on the pinion. but start at 2 teeth and then go from there also dont get the motors hotter than 160 deg. keep them under that temp and they produce the best power .
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-27-2011, 07:53 PM   #183
arn671's Avatar
Trader Rating: 15 (100%+)
Default Timing
I based timing on motor temp-but had it cranked all the way up the last time I ran (last night) and it was still coming off the track at a hair over 100deg. These motors are different, as soon as I threw gearing at it it started to run cooler
arn671 is offline   Reply With Quote
Old 01-27-2011, 08:23 PM   #184
JayBee's Avatar
Trader Rating: 31 (100%+)
Did it get faster at the same time Alvin?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-27-2011, 08:31 PM   #185
arn671's Avatar
Thumbs up
Hey Jaybee, Yep, motor temp dropped and got faster, picked up .3 tenths going up a tooth, and the temp dropped to a hair above 100deg with timing cranked all the way up. There's still one more throttle response profile to try, so we'll see how it goes. The Viper motor is currently geared 3 teeth taller than a D3 and Ballistic. The production version of the speedo is going to be even better according to Weylin.
Old 01-27-2011, 08:37 PM   #186
skypilot's Avatar
Trader Rating: 14 (100%+)
no fair running stuff I can't get.
I think mike was geared at a 3.7 or so with his duo 3
I was geared at a 3.4 with viper, but only with 35 degrees of timing and it came off at 160, I was getting pulled on the straight, so i cranked the timing for the main, but had "tape" issues and pulled it off so I don't have a good second temp reading, but the car was faster.
semi retired..
skypilot is offline   Reply With Quote
Old 01-27-2011, 09:05 PM   #187
man! i cant wait to try this motor again!!...seems like i was way under geared....but has anyone tryed the 12.3 rotor yet??...the 17.5 comes with the 12.5 one right??....i want this motor to work out only me & another guy have this motor...(from the 4tracks we race @)..nobody never heard nor seen this motor b4.....it feels good 2 have something nobody has
Old 01-27-2011, 09:19 PM   #188
savageboy69's Avatar
Trader Rating: 89 (100%+)
That must be how the guys testing the new vtrax10 esc feel
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 01-27-2011, 09:22 PM   #189
true story
Old 01-28-2011, 06:57 PM   #190
ok!ok!...i got a chance to run the motor to day & i was much happier with it 2day...i took the advice of a couple of ppl...& this is what i did
1st..im running spec with a GTB...5000 50C LIPO
I turned the timing all the way up
i geared it 4teeth more then my duo2
i was around 3.8fdr
i was practiceing wit a buddy & he was running a ballistic...we was the same speed on the back straight..but i was killin him in the in field...& he is a real good driver...after 12min my motor came off around 155*
cant wait until sunday to see what i can do on a bigger track & more ppl
so far so good
Old 01-31-2011, 10:06 PM   #191
hopefully we are closer to the release of the vtrax , yay!!!!!!!!!
XB8 2016
XB8-E 2016
XB4 2017
Old 02-02-2011, 08:25 AM   #192
how did the guys with these motors and controllers do at the snowbirds?
gdcopbdcop is offline   Reply With Quote
Old 02-02-2011, 12:15 PM   #193
ekim628's Avatar
The Vtrax 10 and 10R are pretty much finished except for the boost timing profiles. I used the Vtrax 10 17.5 non-boost at the Snowbirds and there were no problems. For those of you running 17.5 classes, I would highly recommend using the 12.3 mm rotors to get more rpm. The Viper Team will be finishing up the boost software for the Vtrax10/ 10R/ One very soon. These ESC's will have outstanding quality and performance.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 02-02-2011, 12:26 PM   #194
ekim628's Avatar
Weylin and I had some bad luck in qualifiers for touring car classes. Steve downs did well in oval. Peter Robinson made it to the a-main in 12th stock and B-main Mod touring. I qualified 13th overall in 12th stock, not bad for not racing on carpet ever Overall a good week of racing and Team Viper was well represented in its first major race
Eric K.
Old 02-02-2011, 01:39 PM   #195
So when can I get one in my hands
XB8 2016
XB8-E 2016
XB4 2017
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
