-   -   Tekin RS overheating problem! (https://www.rctech.net/forum/radio-electronics/453789-tekin-rs-overheating-problem.html)
Simple GREEN 11-18-2010 08:29 AM
I have this problem and everyone I have talked to who dose or has owned a Tekin Esc has had the problem of it running hot.
I was running last night at about 185 after 7 minuets motor is geared correctly it was hardly reaching 120 how can I bring the temps down?
I was told that there were some settings to somehow limit the current therefore helping the temps also would adding a second capacitor help bring the temps down a bit?
Thanks for the help.
BCbud 11-18-2010 09:45 AM
Good day!
Post your setup and what are you running it in and what turn motor?
Simple GREEN 11-18-2010 11:16 AM
Durango Dex410
LRP X-12 6.5
klaymon 11-18-2010 12:06 PM
I'm pretty sure Tekin will suggest an RS Pro for 4WD with a low turn motor. This has been posted before with high temps on the RS with the type of vehicle/motor combo you're running.
wingracer 11-18-2010 02:24 PM
You need a pro. Technically the standard RS can handle up to 5.5 but that's really pushing it so temps will be higher. A Pro should take it much easier.
racer1812 11-18-2010 10:09 PM
^^^^^^^^:nod::nod::nod: what he said.
