sensor wire error on novak havoc with losi motor >
Old 11-15-2010, 12:10 PM
Trader Rating: 18 (100%+)
Default sensor wire error on novak havoc with losi motor
ok, so i tryin to use a losi 21.5 sensored motor woth the novak havoc esc. getting the error to replace the blue wire on the harness. tried a diff harness, same thing. any ideas? tried a novak motor and it works fine, just not with the losi motor.
byohnd is offline
Old 11-15-2010, 08:28 PM
mcdanielbro's's Avatar
Trader Rating: 41 (100%+)
I had the same problem , I ordered a phantom pro 8.5 to run on my havoc and got the same thing . I called novak and spoke with one of the techs, he told me that the havac's where only designed to run novak motors that they wouldn't run anything else. I been runnin a 10.5 SS on it for a year now, no problems...
mcdanielbro's is offline
Old 11-15-2010, 10:49 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
The Havoc requires that the motor has a temp sensor in it (blue wire) most motors don't have this which is why it won't work. If you can find a motor with a temp sensor in it other than Novak it should work, I know there are a couple out there that have it but I don't know which ones off hand.
racer1812 is offline
