WHAT IS A GOOD BATTERY CHARGER
Im getting ready to buy the losi 2.0 rtr. what a good and fast battery charger for lipos and the receiver battery Thanks, Fortega95
I use this myself, the iCharger 106B-plus 250W 6s Balance/Charger
can't fault it, still working my way through it
Hmm
I love my Hyperion eos06060 or whatever it's called. It has it's own power supply built in and charges anything. I got it for 110 shipped on ebay...
It's easy to use...
http://cgi.ebay.com/Hyperion-HP-EOS0...item4cef855575
It's easy to use...
This is what a bunch of us use at our local track and it works great and is economical.
http://www.hobbypartz.com/thac6smbachw.html
thanks
thanks for all the replys
http://www.hobbycity.com/hobbycity/s...dProduct=15167
If you're going to be running 4S, you prob won't be happy with a 50watt output power charger. They will charge a 4S, but it will take much longer that a charger with enough output power. A 50watt charger will limit the charging current to stay under its power limit and this reduced current takes longer to complete a charge.
A charger with enough power will charge a 4S in about an hour at 1C, but a 50watt charger (Thunder AC6, Hyperion 0606i, Venom Pro, etc) will take up to 40% longer depending on the capacity of the lipo. It takes 84watts to charge a 5000mah 4S. There are a few 100watt AC/DC chargers out there (Dynamite Passport Ultra Triton 2 EQ etc)
The iCharger mentioned will not have this current limiting, Hyperion 0720net3 won't either, but these ae DC powered chargers and require a separate epower supply. Be sure to size the charger to your charging needs or at least understand the compromise you wind up with. I see a lot unhappy guys posting when they realize the charger they bought is going to take 100-110minutes to charge their battery.
This is decent comparison of a few chargers...
http://www.bigsquidrc.com/lipo-batte...rger-shootout/
I like my Checkpoint 1030
True
i use swallow eq great charger balances does all types of batteries never played up on me and it is easy to use
The AC6 has 50watts of power on either AC or DC, so power supply won't make a diff for that one. The EQ2 does provide 120watts on DC so it would make a diff running that charger (maybe thats why its $200). Hyperion 06060i is 50watts regardless of input source, so power supply wouldn't matter there either.
Also when starting out having an AC/DC charger is sometimes preferred since its cheaper and is one less piece of equip needed. If you already have a power supply with more than 120watts (approx power needed to run a 100watt charger at full power), you have more options in considering DC powered chargers.
Last edited by Duster_360; 11-03-2010 at 05:43 AM. Reason: misunderstood the question....
