Tekin RS esc ?
The problem I'm having is the drag brake is working about 1 out of every 10 times I accelerate. But it works 100% of the time in reverse(which is not needed I know). The 3 wires are correctly wired ABC. Any ideas?
Do you have the Hotwire for it? Updated recently? If it has not been updated that is one thing you can do to make sure every operation is working its best. Aside from that it could be alot of things. Your best bet is to read thru one of the official RS pages under electric on or off road and see if anyone else has had the same issue, or call or email Tekin. They should be more than willing to help you get it working to your satisfaction.
Make sure you don't have push control on, it'll override your drag brake as it has the opposite effect.
New version v208, set esc to default, then back to my settings. Do have a hot wire and push control is off. thanks guys made email tekin or call.
Drag brakes should not work in reverse. Try running MT1 and see if drag brakes function properly please.
Hey Randy, I don't have much time in with this type of thing (as you can tell). Didn't know what MT1 was so I tried a bunch of different things and not much luck. So I went to default settings and tried it and I had drag brakes. Then I change one setting at a time back to the way I had it set up untill I had no drag brakes. Where I screwed up was neutral width. Looks like 25 and above will work but not below. Thanks for your time.
Oh I still have drag brake in reverse, I have delay on if that makes a difference. Thanks again.
| All times are GMT -7. It is currently 11:10 AM. |
