M11 won't turn on
I have an M11 with Spektrum mod. used it last Sunday and it was fine. I tried turning it on today and it will not turn on. Completely dead, no blue light, nothing on the screen. Tried everything from changing batteries, checking connections, played with the switch nothing. This is my second M11 that had this same problem. The first one had a very similar problem, one minute it was working fine, then i unplug the lipo batt. to charge it, after charging plugged it back to the radio, turned the switch on and nothing. Btw, these are used radios when i bought it, but what are the odds on having the same problems. Any suggestions will be much appreciated. Thanks.
The radio has a fuse in it that pops. It's usually caused by plugging the lipo battery in backwards. You can send the radio in and the fuse can be replaced and we can also put an Airtronics connector on the Lipo battery to prevent plugging the battery in backwards.
Originally Posted by C Verano
(Post 8082707)
Originally Posted by sedan4life
(Post 8082927)
I'm in LA, so can I drop it of instead of sending it in? Airtronics in Fountain Valley? Thanks Chris.
M11
Hi my son also plugged the wrong lipo battery in to the remote. I repair car radios etc in work all the time. Can you tell me were the fuse is so I can fix it myself. We have a race tomorrow and he has no remote. Any help would be great and you could call me at the number below also.
| All times are GMT -7. It is currently 06:03 AM. |
