-   -   hitech warranty (https://www.rctech.net/forum/radio-electronics/442783-hitech-warranty.html)
pballer2777 10-12-2010 03:00 PM
hitech warranty
i have 2 hitech servos that work intermittently and i want to send them back to hitech for warranty. does anyone know how long the warranty is good for? both servos were bought april of 2009.
JAMMINKRAZY 10-12-2010 03:10 PM
2 years.;)
http://www.hitecrcd.com/files/serviceform.pdf
losi_racer 10-12-2010 04:13 PM
this happened to a hitec of mine, i just havent sent it in, anyone know the reason for this?
Semple 10-12-2010 06:04 PM
Solder joint on the board, probably. I sent two back for it.
kcobra 10-12-2010 10:26 PM
Hitec warranty is the best in the business. General consensus is if the servo is still being manufactured then they will replace it free of charge, even if it is over the 2 year period. If it is no longer being manufactured then it falls back to the 2 years, either via the date on the invoice or the sticker on the servo.
Duster_360 10-13-2010 06:39 AM
Originally Posted by kcobra (Post 8064221)
....Hitec warranty is the best in the business....
+1 !! They've replaced one or two for me...no questions asked.
pballer2777 10-13-2010 07:04 AM
just came back from the post office. hopefully it won't take forever.
lil-bump 10-13-2010 07:09 AM
My son twisted the steering wheel off of my Hitec CRX transmitter. Sent it in for repair. Hitec replaced the entire transmitter free of charge with free return shipping.
Hitec has the best customer service in industry.
HB Moose 10-13-2010 09:11 AM
+2 , I sent in two out of waranty servos for new potentiometers. No charge
Klimpen717 10-13-2010 10:57 AM
I had a 7955TG that just died and sent it to Hitec in Germany and got one back without any hassle. Took about 3 weeks!
rotarynut 10-13-2010 06:42 PM
Beat this, my 7955tg was going to full lock for no reason,sent it in twice for the same problem, Hitec sent me back a brand spanking new one, can't complain about that. HATS OFF HITEC!!!:nod:
mtbkym01 11-01-2010 12:38 AM
Hope you are all correct
So much for how good Hitec's are, Had a 7954 go bad after only 1 race day :flaming:, awaiting a response from Hitec as to warranty.
It's a pity, coz all I read was how reliable Hitecs were/are, and this has left a pretty bad taste in my mouth.
All I know is my other ACE servos have been bullet proof.
Klimpen717 11-01-2010 09:41 AM
You have to be a bit realistic here I think.
Do you REALLY think any servo brand will have a 0% failure rate?
Of course a servo will die randomly from ANY brand.
You just got the bad one and had to be part of the statistics!
You have to think bigger then that.
If you say ACE is a good brand that mean they will have, let's say 20 out of a 1000 to break. Compare that to let's say 40 out of a 1000 from hitec that is broken.
Now you can say that Hitec is the worse company and they make bad servos compared to ACE.
Then you have the next step. Let think for a while that Ace and Hitec both have equal amount of bad servos. Who's has the better customer service?
merdith6 11-03-2010 02:26 AM
HMM
I have had several Ace servos and one died, sent it in, forgot about it, then one day I got a brand new one in the mail. I like ace and hitec....
bentgear 11-03-2010 02:55 PM
So much for how good Hitec's are, Had a 7954 go bad after only 1 race day , awaiting a response from Hitec as to warranty
I don't think anybody hardly bothers to burn in a servo any more now that they have gotten so reliable. Maybe they should. You always have a chance of failure in infancy, if it lasts thru this phase it should be around for a while unless external circumstances prevail. For the prices charged companies can't afford to do stress test on each servo they manufacture. I hook every new servo up on a servo tester and let it run for several minutes checking for torque by simply putting pressure on the output shaft periodically and checking the case for heat.
Ed M.
