-   -   sensored with a sensorless esc. ? (https://www.rctech.net/forum/radio-electronics/441813-sensored-sensorless-esc.html)
shortcut 10-09-2010 10:06 AM
Can you run a sensored motor on a sensorless esc. ?
Thanks, Jeff
mattleegee 10-09-2010 10:19 AM
Thanks, Jeff
I think the other way would work if the ESC had both abilities... but the way your trying seems like a fail
wingracer 10-09-2010 10:32 AM
Yes you can. It's the other way that wouldn't work. A motor with no sensor will not run on a sensor only esc.
shortcut 10-09-2010 10:49 AM
So as long as I don't exceed the recommended number of winds it should work.
Thanks, Jeff
Team Ash 10-09-2010 02:30 PM
Sure will.
It will work. I run a novak 6.5 with a hobbywing 60A sensorless esc. I have been running it for over 18 months and even won last years club st truck open class with it in an associated T3.:)
Terry
