Manufacture ballance plugs
This is all I've been able to find and I suspect its not what you're looking for since you'd have to use both sides since this is a 2 -4S connector.
http://www.rcdude.com/servlet/the-13...s--dsh-/Detail
What brand of lipo are you wanting this for?
What charger do yo have? What type output conectors on the charger? There are several diffeent setups premade that are almost as cheap as the conectors.
Here is the one I use. You can get it from several places.
http://www.allerc.com/product_info.p...oducts_id=3702
John
John
Thanks for all the replies. I did locate the connectors and contacts I was lookig for at DIGI-KEY.
The ones I was looking for are a JST 3 position housing w/ 2.5 mm spacing JST# XHP-3. They are available up to a 7 position. The contacts are JST # SXH-001T-PO.6.
I did find 4 Venem battery connectors that I had tucked away. I am just going clip off the JST connector and wire leads and splice into it to make what I need. These are going to be used on the new IMAX 4 in one DC charger and I was looking for 4 leads approx 12-15 in long. the charger has the ballance ports built into the side of the unit.
Thanks again;
Bob O
Thanks again;
Bob O
