Airtronics m11x problem
hey, does anyone have this problem where you turn on the transmitter and the receiver and the servos dont work? the light is on on the receiver but the servos doesn't work like it's not binded right or something.. but no matter how many times i rebind it still doesn't work. Usually what I have to do is to play around with it by turning the transmitter and receiver on and off until it works and it doesn't happen to me all the time either.
m11x Problem
Yes I have the same problem-sort of! I binds and works ok then the throttle stops working! I turn off the Rx and then back on and it works-usually. but it may quit again at any time. This is all on the bench, I have not tried to run it yet.
I am using a 92524 Rx on FHHS-2. You figure out anything yet?? Ned |
Originally Posted by aarcobra
(Post 8172082)
| All times are GMT -7. It is currently 08:10 AM. |
