Sanwa MT-4
http://www.redrc.net/2010/09/sanwa-m...z-transmitter/
http://www.redrc.net/wp-content/uplo.../SanwaMT-4.jpg Will it be an high-end radio or a mid/low-range one? |
It's hard to tell from the pics and description but I would bet it's a mid-to-entry level radio based on the naming.
http://i191.photobucket.com/albums/z...4Telemetry.jpg
http://bbs.rc-evo.com/attachments/da...da27c6e1e0.jpg MT-4 features: ● 4 channel control (built-in antenna) • Large LCD screen (128x64 dot) ● New receiver (RX-461) ● Built-in telemetry function (receiver voltage, speed, temperature) ● Dual D/R ratio adjustment ● SUB TRIM ● TIMER (Lap / INT / Down type) ● ABS ● The volume adjustment (steering, throttle adjust volume) ● AUX1, AUX2 mixed control ● CH SET 1-4 ch all settings (D/R, EPA, SPEED, EXP...etc.) • Fail Safe funtion • 8 digit username and model name input ● 20 group model memory ● Modulation (DS2, FH3, FH, 3F, FH4T) ● Throttle mode (5:5 , 3: 7) ● TX Power source (4 x AA batteries) ● Compatible receivers (RX-371, RX-442DS, RX-451, RX-451R) ● Trigger position adjustable (front/rear slide 5mm , left/right 3° ) http://bbs.rc-evo.com/attachments/da...2953ba5bc3.jpg |
Thanks, looking at specs looks like a mid-level radio, similar to the spektrum DX3S (telemetry, etc.) ;)
pre-selling at japan for Yen28xxx, available Dec, 2010
Temperatere
RPM *RX-461(FH4T)receiver is neccessary for telmetry function. Compatible with the full line of Sanwa Car 2.4Ghz FHSS-2 receivers. RX-371 RX-442FS RX-451 RX-451R Equipped High Speed Telemetry !! The world's fastest response !! Full Adjustable Trigger/Wide Grip Pad (temperature x 2 system) (motors operation) (receiver voltage) Large Full Dot Display(128x64) Direct Model Select/20 Model Memory The setting of a more best, more driving position is possible back and forth/right and left by a changeable, possible full, adjustable trigger and wide grip pad attachment. 2.4GHz NEW S-LINK FH4T System Is Integrated Into The Radio System MT-4 is the world's fastest response radio which is equipped Telemetry in comparison with competitiors. High speed information update of telemetry with Fastest response FH4T system. Easy-to-read LCD Disply and delicate setting is enabled. This allows you to switch model by one touch operation. |
Sanwa release MT-4
nice from the 1st i see it abit same with dx3r,when will this radio coming?wana test it out is it same with m11x....:sneaky:
Sanwa MT-4
Can I use 2 temp sensors instead of a temp sensor and a rpm sensor?
Originally Posted by Kensei
(Post 10448425)
has any one had issues with telemitry or range
ive just purchased a mt4 set with telemitry.having problems with rpm and temp not working unless model close to me.model goes out of rang ocasionly but only coz long way away.temp and rpm only works for bowt 50meters then seems to stop working wile model in range and radio set working fine.this set is in a 1/5th scale hydroplane with 26cc zenoha.any one no how to help.thanks.
How best to fasten the sensors on the esc and the motor?
For instance: - tyrap - duckttape Other options? I am looking for a servo to go with this transmitter in the Awesomatix A700. Futaba BLS551 is my first choice. That would work? Any other suggestions and/or advice? |
| All times are GMT -7. It is currently 01:55 AM. |
