-   -   Steering Servo Question (https://www.rctech.net/forum/radio-electronics/437319-steering-servo-question.html)
xevious613 09-23-2010 03:44 PM
Using the Hi-Tec HS7955TG for steering servo but without using a servo saver. Everytime I bump the front tires just a little, the steering gets out of alighnment. I then tried using a servo saver but still getting out of alignment. This is the first expensive servo I have ever used and hoping I didnt already ruin it by not using servo saver! Any advice or comments welcome. Thx.
BCbud 09-23-2010 04:16 PM
Good day!
What are you using it in? Some cars hav a built in servo saver and if it is too loose it will not center.
xevious613 09-23-2010 04:34 PM
Losi 8ight-E, and after checking the owners manual.. it does have a servo saver, but it all seems to be tight. If I hold the servo horn and push on the wheels, the saver seems fine.
The servo was purchased new and only used 5-6 runs before started noticing problems.
xevious613 09-23-2010 07:45 PM
Found the problem to be a plastic insert inside the servo horn to fit on the metal servo gear was stripped out. What a relief. ;)
shanem121 09-23-2010 11:13 PM
Invest in a aluminum horn, They are worth the few bucks
xevious613 09-24-2010 03:21 PM
I will definitely get one, thx for the tip.
oldpugva 09-25-2010 06:01 AM
Ran in to this problem after changing a server as well. Found the 'reuse' of the horn was my issue. Turns out I needed to change the horn to the right manufacturer. My kit had other horns with letters branded to them. There was a 'H' for Hitec, etc. I ended up just replacing the original plastic horn with a metal version. Problem solved!
