Savox SC-1267MG Servo
#17
can anyone explain the difference between Savox SC-1267MG and Savox SC-1267SG?
#18
I had to send one back for warranty(failure was my fault). NO questions asked it was replaced. Great customer service...
#21
Well Im going to sit on the fence. This weekand I built a RC8Be with a Mamba Monster combo, spektrum receiver and a savox 1256TG servo. I couldnt even drive it due the servo glitching. Replaced it with a old Hitec and the problem fixed.
Then tried the same 1256TG Savox servo in my Xray 808 with a KO Pro receiver, Life receiver pack and it works fine, no glitching at all.
The reason there's no issue with the receiver pack is because the battery can easily handle the load from the servo, hence no voltage drop.
An easy way to check if this is your problem is to watch the green light on the receiver, if it goes off while your turning the wheels, you found the problem.
#22
The savox has a tendency to glitch with Spektrum and JR equipment only.
#23
There has been quite a few people who has had issues with the savox servos on just about every speedo out there. The fix is normally pretty easy. Just get a novak or spektrum capacitor and plug it into a spare port of the receiver. In some cases people had to install an external bec to power the receiver, but even that is still a relatively easy fix. This problem is not just confined to savox servos either.
The problem is mainly due to the fact that high power servos are drawing more current. And now that we're running these high powered servos in our electric cars, its showing up the limitations of esc's in terms of powering these high torque servos. And its also not the esc manufacturers' fault since they're trying to keep the esc size as small as possible too.
#24
These servo's are worth their weight in gold. The price on them just doesnt seem right for the performance.
If you havent tried one, pick one up today!
#26
Very smooth powerful servos, put my Hitec's in the box for backups!
#28
SC-1267SG differences from old to new
Some interesting information on the Savox SC-1267SG servos. It seems they have changed thier shape. If you look where they would mount they would seem to be a bit short underneath but taller up above:
The one on left is from the one on my 1/8 buggy and the one on right is a brand new one.
Interesting.
It seems the older one had weird glitching problems after awhile of running, but newer ones seem fine.
Interesting.
#29
Interesting.
Interesting.
