-   -   LRP Sphere comp problems (https://www.rctech.net/forum/radio-electronics/430851-lrp-sphere-comp-problems.html)
Alleman Designs 09-01-2010 06:08 AM
Having a little trouble, I'm using a sphere comp speedo, and a lrp x-11 13.5 turn motor. Once I set up the speed control, sometimes it spins the motor, and sometimes, the motor just makes a faint whining noise and won't run. If you give the spur a little bump, it works fine. When it doesn't go on it's own, and you hold throttle, the mode lights alternate blinking red and yellow. Does anyone have any ideas?
I have tried two other motors and sensor wires, same result with all.
