-   -   charging in the field (https://www.rctech.net/forum/radio-electronics/427304-charging-field.html)
wow 08-20-2010 02:29 AM
about how much charging can i expect to be able to do out in the field from my full size car's battery and still be able to drive back home? i dont want to be stranded but i need to charge my batteries!
wallot 08-20-2010 06:18 AM
it depends on what you plan to charge :)
just check car battery with a voltmeter once in a while and you should be ok whole day
racer1812 08-20-2010 06:22 AM
+1, it all depends. I've run 2 chargers off of my truck battery charging 7-8 5000mah 2s packs with no problems.
Harry Sachs 08-20-2010 04:49 PM
I've charged my 2s 5000 packs probably 20 times on the truck battery.... started right up. I do bring the jumper cables just in case.
