Recommend me a servo please.
I recently purchased a Thunder Tiger KT8 Kart. Apparently there is a durability issue with the stock servo from what Im told. It uses an 1/18 scale servo. Any recommendations? I'd like to keep the cost down. This is going to be the spec class carpet car where I race in the winter this year. Its actually quite fun to drive.
This is the one I have but its orange. http://www.amainhobbies.com/product_...rce/google_ext |
Align
I used an Align DS410M digital servo with metal gears. It is a little tight on the bracket but a little dremel shaving and it fits tight. The main thing is the metal gears and the fact that the servo horn fits.
The link says product not found, but I know what one you're talking about. I can't tell from the pics I see if the servo has one mounting hole type ears or two hole type mount.
If its one hole try a Hitec HS-82 and if its two holes look at the HS-65 servo. |
doesn't matter how many holes because they are not used for mounting. key is size and servo horn mount dia..
| All times are GMT -7. It is currently 05:41 PM. |
