-   -   Hitech screws (https://www.rctech.net/forum/radio-electronics/420274-hitech-screws.html)
Jaz240 07-26-2010 07:08 PM
Hitech screws
Does anyone have a replacement hex head screw for the Hitch servos for the servo horn. Their philips head screws are just really weak and I would like a Hex head alternative. What size and where to buy with maybe a linky dink would be great if you can oblige.
Thank you,
James Allara
mthird 07-26-2010 07:33 PM
Jaz, they are 2.6mm. I tried searching on the 4C site, but can't find any.
sickboy 07-26-2010 07:39 PM
OS backplate screws.
Jaz240 07-26-2010 07:41 PM
Ok now at least I have the size and a possible replacement. thank you guys
Jaz240 07-26-2010 07:47 PM
subscribing
bentgear 07-26-2010 08:05 PM
Jaz, instead of using a phillips screwdriver on them get a set that conforms to JIS standards. Thats what most of the metric screws actually are. The JIS version do not cam out of the screw like a standard philips will do.
Ed M.
sickboy 07-26-2010 08:48 PM
just type in 2.6 in the search window on amains website. it will show like 400 items, narrow it down with the drop down. you want 2.6x7 or 8. like 20 companys make them.
Jaz240 07-26-2010 08:58 PM
Thanks I'll try that
CWILK 07-26-2010 10:26 PM
http://www.amainhobbies.com/product_...-Head-Screw-12
Jaz240 07-26-2010 11:16 PM
Originally Posted by CWILK (Post 7723871)
winner! thanks bro
Jaz240 07-26-2010 11:17 PM
Ed M.
appreciate the advice Ed, but I was hoping to not have to buy new tools. i think that last link will do the trick just fine
bentgear 07-27-2010 01:27 PM
But if you ever start using a set you will use them on every phillips style screw you can find. Now if I could only find some with a 1/4 " hex head so I could fit them in my electric screwdriver.
Found out about them by accident when i built my first TRex heli. I used the 2 supplied jewelers style screwdrivers when I built it. Everybody that was building them at the time was bitching about the crappy screws but I didn't have a problem. They had used regular phillips screwdrivers. The ones that came in the kit were JIS.
Ed M.
Jaz240 07-27-2010 09:06 PM
I will look into them. They sound great
