receiver help
Hey guys. I have a dx3 that came with the telemetry and sport receivers. I used the better one for awhile w no problems. Washed and detailed car and rec wouldnt work. I tried to then use the sport one. Whenever I plug the throttle in the light goes out? I tried to go back to org one and whenever you plug in the throttle or steering the light goes out. Meaning it stays on the the first one then goes out when second is plugged in. Help please
Originally Posted by Falcon422
(Post 7716467)
If it's doing it with 2 different Rx's, I would suspect the ESC or servo. If you have one of those to swap out, try that.
Have you tried to re-bind them? Receiver+water=BAD
Are you going through the bind process each time you try a different reciever, it needs to be followed
Cheers |
| All times are GMT -7. It is currently 06:19 AM. |
