Need Life Batterie for Receiver
I am running a mugen mbx6 M spec with a Futaba 603FS receiver and two Futaba servos. I would like to go with a quality life batterie for my receiver. Any help
Also right now I have 1900 NImh pack but I need something for longer mains.
http://www.b-p-p.com/product.php?pro...&cat=65&page=1
You need the convert plug & charge plug.or solder in an extra rec plug in back of the heavy plug. You can full charge in 15min if need be @ 4C. Also they have weird balance plug. Like 4s I moved wires in middle sots cut off 2 outside empty ones "real easy just don't short wires You can do one at a time". They plain last longer than the MAH looks. Full 6.5 for the long haul. LIFE charge a must, most #6 based chargers do well " all the same on the inside". I'll never look back. Charge batts a month later ready to go
