-   -   need to fix servo!HELP! (https://www.rctech.net/forum/radio-electronics/405202-need-fix-servo-help.html)
Rooster71 06-04-2010 10:50 AM
I was checking my gears in my Losi digital servo and my 6 year old turned the post that connects to the actual servo arm. Now I can not get it together right. The gears are in right place, but i can't figure out the correct position. One time it will turn in direction of opening throttle, but no movement for brake. Another position nothing at all. Anyone have any ideas? Do I just need to buy another?
shultz 06-04-2010 11:05 AM
I've not opened up this servo before BUT every servo I have opened up will have the pot centered in line with the length of the case(longer portion) so try this.
The pot should have two flat spots on it for turning the main gear... put it the so the lenght is centered with the servo body, now look at you're main gear... if there is a pin or other form of protrusion that would hit stops molded in the upper part of the servo case make sure the pin/lip what ever it is, is also in line with the pot and length of the servo case.
By doing the above you should be back in business;)
