Looking For A Bit Of Radio Advice
I'm looking at a Futaba 3-ch radio system for a possible replacement for the RTR radio in a Nitro TC4. What do I need to do in order to fully replace the radio in this, because I'm gonna guess it's not a simple "switch the receiver and radio" job. I could definitely use some help with this, thanks!
If you go with am FM tx/rcvr (like 3PM) its just a matter of unplugging your old recvr, removing same, mounting the new rcvr, running the new antenna, then plugging everything back in correctly, steering, th/brake and battery. Then setting end points to limit steering travel and th/brake travel too. That will require a little reading in the manual to find out how to make the adjustments.
If you go with a FAAST setup (like 3PM-X), still pretty much the same except you have to bind the rcvr and the tx together which takes all of a few minutes. |
Originally Posted by Duster_360
(Post 7490361)
If you go with a FAAST setup (like 3PM-X), still pretty much the same except you have to bind the rcvr and the tx together which takes all of a few minutes. Futaba 3PM-X Receiver/Transmitter Combo |
Go here and dn load the manual -
http://2.4gigahertz.com/downloads/downloads.html Read pages 22 - 25 to give you an idea of what is involved in installing and setting one of these up. |
| All times are GMT -7. It is currently 05:40 PM. |
