-   -   Help with Nomadio sensor radio (https://www.rctech.net/forum/radio-electronics/403314-help-nomadio-sensor-radio.html)
cyrrus 05-29-2010 09:34 AM
hey guys a bit of help is needed.
I have a nomadio radio I'm borrowing from a friend while my radio is sent back for repair.
the problem i have is the radio will bind with both the specktrum rx. but if the car are on for working on, either model memory will control both car. not just one or the other. is this a common problem or is there a simple solution i'm on doing right. lol
bentgear 05-29-2010 05:18 PM
When using the Spektrum receiver and the beta software on the radio it is not smart enuff to do madel match. So turn the one don't want off, should be doing that anyway.
Ed M.
BCbud 05-29-2010 05:26 PM
Good day!
My DX2.0 would do the same thing as it dosn't have model match. My new DX2S will only run the model selected and nothing else as it has model match.
See you at the track, Neil.
