-   -   saddle pack help (https://www.rctech.net/forum/radio-electronics/403307-saddle-pack-help.html)
birdman-27t 05-29-2010 09:05 AM
saddle pack help
hello
i just bought 2 saddle packs 2-cell 6000mah 30c
i dont get how to wire them up with the leads provided
the lead has a deans connector going to + & - gold plugs off these is a balance plug,with a small blue wire going to a another black wire with a gold plug on each end!
thanks:confused:
BCbud 05-29-2010 10:07 AM
Originally Posted by birdman-27t (Post 7471830)
hello
thanks:confused:
From the deans conector, the + will go to the positive of the first battery and the - will go to the negitive of the second battery. The still open + & - will get conected to each other. This will wire them in series and givee you your 7.4 volts.
Hope this helps.
birdman-27t 05-29-2010 10:29 AM
ok got that
the wire that joins them together 1 plug has a blue wire to it from the blance plug,does this go to the + or - which are left on the batterys,thats more what confused me.
thanks :cool:
BCbud 05-29-2010 10:40 AM
The jump wire has the same voltage at each end, it dosn't matter witch side the ballance wire is on.
birdman-27t 05-29-2010 10:48 AM
ok thanks for your quick replys
its all clear now :nod:
