Hyperion 0610i Duo II
I got a Hyperion 0610i Duo II charger and bought a IP 5000mAh 40C lipo battery.
However, the balancing plug is a little one with 3 pins. My charger's balancing has only 4 pins or much bigger. What should I do? Any suggestion? Thank you. |
The Duo (or any of the Hyperions) used to come with only the Hyperion style balance adapter board. There are 3 other types of balance plugs in popular use so you need one of the other adapter boards. The other types are the JST-XH (also called the Align style), Thunderpower type, and the Kokam type conmnector. There are two that could be called 'small' connectors. Look at the listings here and see if your lipo is listed - it'll tell you which adapter board you need to buy -
http://www.allerc.com/product_info.p...oducts_id=3160 What brand is your lipo? |
Originally Posted by Duster_360
(Post 7468816)
http://www.allerc.com/product_info.p...oducts_id=3160 What brand is your lipo? Would the JST-XH works with my DuoII? |
Unless you have a strange balance adapter board, the board should have a 3 pin connection for a 2S. They are all made this way, I have one of each type adapter board sold by Hyperions and they all have a 3 pin socket on the board for connectiong a 2S lipo balance plug. Maybe you have something different?
If this is your lipo - http://www.rcmart.com/catalog/rc-bat...e-p-30503.html That appears to be a JST-XH plug on the linked lipo and you'd need this - http://www.allerc.com/product_info.p...oducts_id=3159 |
| All times are GMT -7. It is currently 03:58 AM. |
